Compact power conditioners, what do you have?
mikeyb128
I've been exploring the world of compact power conditioners that are available in Canada that don't cost an arm and a leg. I wanted to add one before my Nordost q base, I also wanted something small, that won't take up a huge chunk of realstate in my rack.
I came across a furman AC 215A on my local kijiji new in box for 140$ bucks. Went and picked it up and what do ya know this guy had a HUGE system, focal electras, bryston, a crazy system. Ended up picking this little gem up for 120 bucks, tape wasn't even broken on the box.
I don't have any problems with my sound, but have had this hooked up for about a day, and I am really surprised what I found, lower noise floor, dead quiet. And everything seems way smoother. I can't quite explain it.
A buddy of mine has a surplus of military grade stranded 10gauge silver coated wire, so he made me a power cord to go to the furman. Braided, shielded with furutech connectors. I am pleased! And was free! Best 120$ bucks I have spent in a while!
What do you have?
What do you have?
2 channel:
Theater:
Theater:
Here's some eye candy.
I also realize this is only rated to handle 10amps. My pre amp, CDP, and TT will be the only thing hooked to this, and I seriously doubt those combined will ever hit 10 amps.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
'good power conditioner' and 'compact size' is an oxymoron.
Speedskater wrote: »'good power conditioner' and 'compact size' is an oxymoron.
I take it you've never seen the PS Audio Dectet, Shunyata Venom, the picture of the Furman right above you?
PS Audio Detect, is what I have.
– Kevin Alfred Strom -
Furman PL Pro DMC
It's thin, and fits into the rack taking up very little space. They also make a 15 amp version.
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
I have one of the AC 215A as well for my alarm system. Surges love to go over low voltage wires and I can't afford to redo the built in alarm system if there is an issue. I'm likely buying another one or two for other rooms if I can find them for the right price again (under 100).
I had a Furma PL Plus Series II that did a good job too. And then the non small APC H15s.."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
The AC 215A supposedly has the features of the PL series. It's a feature packed little box. Under a 100 is a steal.2 channel:
Theater:
Bill Whitlock thinks that a good power conditioner needs to be the size of a refrigerator.Upstatemax wrote: »
I take it you've never seen the PS Audio Dectet, Shunyata Venom, the picture of the Furman right above you?Speedskater wrote: »'good power conditioner' and 'compact size' is an oxymoron.
Power-line filters in “conditioners” only begin to work at frequencies over about 40
kHz … but these frequencies do not cause either common-impedance coupling in
unbalanced cables or common-mode voltages at balanced inputs, provided that cables
with normal coaxial shielding is used in either case. Power-line filtering, unless the
filter starts working at a few hundred Hz (which would make it the size of a
refrigerator), are useless in the reduction of hum and buzz ... duh!
I used to be under the false sense that only those that lived in old houses or inconsistence power areas needed line conditioner. Not until I had an issue with my 2 channel setup sharing the same line as the kitchen. I was getting popping noise from the microwave and frig. After getting a Paramax 500 dbs (sister units with Furman) I was sold, Not only did it solved my issues but also created a cleaner noise level (deeper blacks) and help tighten up the bass. I have a line conditioner on the HT setup, and Master bedroom also.Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
I use the Furman AC215 ( no A) for my headphone rig at the office. I work for a software company, so there are massive numbers of computers and other electronics. Background is dead quiet. Extremely happy with it.
