Opinions on the Krell SACD Standard, early model..
nooshinjohn
Looking at upgrading from my Pioneer Elite D9... I have zero experience with Krell as a brand and I only know the Pioneer and Marantz players. thanks for the advice.
PM Wardsweb (Luther) he has one set up on one of his rigs. We did listen to it but not to the extent for comparison. I know they are built solid but Luther would be able to comment on comparisons.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Dang John.....you didn't even sell the condo yet and your already looking to skim some off the top. lolHT SYSTEM-
lsi 9's -
Go buy a used Cary 306 pro version, like Ray has....you won't regret it. I've seen them used for about 3500.HT SYSTEM-
lsi 9's -
Not to slight pioneer (even the elite series) but the Krell just has to be a large step up. Their amps are for sure. I would like to hear that as well.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
