Opinions on the Krell SACD Standard, early model..
Looking at upgrading from my Pioneer Elite D9... I have zero experience with Krell as a brand and I only know the Pioneer and Marantz players. thanks for the advice.
    txcoastal1 Posts: 13,519
    PM Wardsweb (Luther) he has one set up on one of his rigs. We did listen to it but not to the extent for comparison. I know they are built solid but Luther would be able to comment on comparisons.
    Dang John.....you didn't even sell the condo yet and your already looking to skim some off the top. lol
    Go buy a used Cary 306 pro version, like Ray has....you won't regret it. I've seen them used for about 3500.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited February 2016
    Not to slight pioneer (even the elite series) but the Krell just has to be a large step up. Their amps are for sure. I would like to hear that as well.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
