Polk Audio LSi M 703
  • PSOVLSK wrote: »
    I have the P5, but I haven't hooked it up with my 703's. I feel confident in saying that it would be a good match. HT bypass is a nice feature and the sole reason I own one. I think you'll be very, very happy with this set-up.
    You've got me thinking of running my P5/703 together. If I get around to doing it in the next few days I'll post my impressions.
    Reach out to DSkip here on the forum. He's a Parasound dealer and he'll take good care of you.
    After reading some here I thought the P5 and 1500A would be a good choice for Music (my current budget) and leave some doors open for HT. But I'm not sure, that is why I'm checking in here. :)
    I'll follow up with Skip.
    HT : Pioneer Elite VSX-01TXH | Sony BDP-S350 | Parasound HCA 1500A | LSiM 703's | SVS SB-2000 | Polk Audio RM101 | Polk Audio RM7 | Sharp Aquos 52" LED | Speaker Cables - MIT AVt3 | ICs - MIT AVt3 | Harmony One
    Headphones : Sennheiser HD-600 | Little Dot MK III tube amp | HRT - Music Streamer II DAC
  • Mikey081057
    Mikey081057 Posts: 7,127
    Yes the P5 has dual sub outputs and bass management. I have 2 subs connected. All you need in 1 pre.
    Garage | Polk Monitor 5B's
  • deronb1
    deronb1 Posts: 5,021
    Great! Can o corn!
  • Yes the P5 has dual sub outputs and bass management. I have 2 subs connected. All you need in 1 pre.
    Nice! Thanks for the info!!
  • What about the McCormack DNA 1 Deluxe and Parasound P5?
    tonyb wrote: »
    It would be double what I was hoping to spend on the Parasound HCA 1500A...but since I don't have and amp or heard either of these two I figured I'd get some feedback.
    Also, I've seen on some posts where you talk about reconditioning and recapping amps. How does one know when that should be done with older amps?
    zD
  • Nightfall
    Nightfall Posts: 10,083
    ZenDawgg wrote: »
    Open it up and look at the large power caps, if they're starting to bulge they need to be replaced. The alternative is to just do it, better safe than sorry?
    afterburnt wrote: »
    Village Idiot of Club Polk
