Need Turntable Help
Okay so I broke out a very bright flashlight and had a look. I was incorrect. The female end of the green wire - something isn't right. The other three I can clearly see the brass colored tubes that the pins slide into but on the green wire (bottom left) I don't see the brass colored tube, only a small portion of it, and I just see white looking into that one. Plastic? Either the brass tube is plugged up with something white, it's crushed, or? Manufacturing defect? I grabbed a very fine fishing hook. It goes into the other three but is hitting something and not going into the female end in question.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Actually Stanton made some nice sounding pmounts, so as far as that goes I don't think it's a bad cart. Yes the Denon 103 would be a huge upgrade though.
Saw in another thread you had what looked like a couple of technics linear tracking tables. I just inherited a technics sl j2 and wondered if p mounts were all the same shape. It's got some flavor of AT and would like to upgrade but it's real skinny and am not familiar with pmounts.
McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
