new mid drivers for SDA 2b's
Howdy all,
Just ordered new tweets and mids for my 2b's and are suppose to arrive tomorrow.
As I remember (not so clear, hiccup) from 10 years back, the mids DID NOT come clearly labelled as to positive and negative.
Do the ones nowadays come labelled?
If not, how can I be SURE, that I am putting them in correct phase?
Thanks in advance,
Dale
Polk SDA 2B's
Carver TFM-45
Sony X33ES
Theater:
Sony XBR-850b
Denon 1709
Rti-6 by 4
Csi 3
Paradigm PSW10
  • dale442
    dale442 Posts: 40
    edited January 2016
    I just removed the drivers and found that in a "connectors down" configuration that the stereo drivers both were white wire to the right pin ( as you look at them ). By the wiring diagram, this is backwards. But the diagram does not show, for SURE, of a " connectors down" config.
    Can someone clear this up for me? Also, the positive/negative config of the dimensional driver as well.
    All help is welcome
    Dale
    Polk SDA 2B's
    Carver TFM-45
    Sony X33ES
    Theater:
    Sony XBR-850b
    Denon 1709
    Rti-6 by 4
    Csi 3
    Paradigm PSW10
  • slbenz
    slbenz Posts: 97
    When I ordered my replacement tweeter for my 2B recently, the Polk Tech Support person walked me through the proper connectivity for each driver even though I didn't need it. You may want to call Polk Audio for the correct connectivity for each driver to double check.
  • I think you will have a red dot near the positive or plus terminal, on the MWs
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • dale442
    dale442 Posts: 40
    Thanks for the reply.
    I have talked to Polk support and now have the proper config of the driver connectors.
    They are, as you look at the driver as if it were in the cabinet, connectors facing down.
    Positive is the LEFT connector
    Negative is the RIGHT Connector
    Maybe this helps someone else down the road.
    Enjoy,
    Dale
    Polk SDA 2B's
    Carver TFM-45
    Sony X33ES
    Theater:
    Sony XBR-850b
    Denon 1709
    Rti-6 by 4
    Csi 3
    Paradigm PSW10
    F1nut Posts: 52,011
    There should be a red dot next to the positive connector. In the down configuration that will be the left connector.
  • dale442
    dale442 Posts: 40
    edited January 2016
    The new drivers have arrived. Just installed (nice and tight :) ) and having my first nibble at them.
    Thanks for all the help!
    Dale
    Edit
    No red dots to specify the positive connectors on mids but, are there on the tweets.
    Polk SDA 2B's
    Carver TFM-45
    Sony X33ES
    Theater:
    Sony XBR-850b
    Denon 1709
    Rti-6 by 4
    Csi 3
    Paradigm PSW10
  • dale442
    dale442 Posts: 40
    edited January 2016
    After the new drivers sitting in this room for the first time.
    Not the best of rooms for it but we will see how it works.
    And no, the fireplace does not work and next on the list for removal. Angled wall and all.
    Dale
    Polk SDA 2B's
    Carver TFM-45
    Sony X33ES
    Theater:
    Sony XBR-850b
    Denon 1709
    Rti-6 by 4
    Csi 3
    Paradigm PSW10
  • motorhead43026
    motorhead43026 Posts: 4,031
    edited January 2016
    That Carver will push those 2B'S real good.
  • dale442
    dale442 Posts: 40
    edited January 2016
    It does, and has been for over twenty years. The trio has been together that long. Have a Carver CT6 pre buy prefer the "Cd direct" sound personally.
    Nice Olds by the way!! 68 or 69, cannot see the front or tail.
    Dale
    Polk SDA 2B's
    Carver TFM-45
    Sony X33ES
    Theater:
    Sony XBR-850b
    Denon 1709
    Rti-6 by 4
    Csi 3
    Paradigm PSW10
  • motorhead43026
    edited January 2016
    Good eye, 68 442, original engine 400cid, original Muncie close ratio 4-speed and original 3.91rear gear. Other than valve stem oil seals the engine has never been down, stock bore , stock rings etc. It is starting to get tired @119,000 miles. It is still a torque monster, well used but never too abused...lol.
    And thank you.
  • dale442
    dale442 Posts: 40
    edited January 2016
    I'm an Olds guy...hence the 442 in my name. 119000 is just starting to break in!!
    Must be sweeeeeeet with the 4 gear!
    Polk SDA 2B's
    Carver TFM-45
    Sony X33ES
    Theater:
    Sony XBR-850b
    Denon 1709
    Rti-6 by 4
    Csi 3
    Paradigm PSW10
  • I was going to ask you that the other day if the 442 had any significance as in Oldsmobile's. Nice, great cars they are indeed.
  • dale442
    dale442 Posts: 40
    They are indeed. Had many over the years. Still have an 87 442 resting in my mom's garage. Certainly not one of the good ones tho.
    Polk SDA 2B's
    Carver TFM-45
    Sony X33ES
    Theater:
    Sony XBR-850b
    Denon 1709
    Rti-6 by 4
    Csi 3
    Paradigm PSW10
  • The G bodies are cool, they are catching on.
  • dale442
    dale442 Posts: 40
    edited January 2016
    It has ~just~ enough torque and 373's to make it fun. I'm the second owner, all documentation ect ect.... Winter here, so is now resting
    My dream is to own a 70 W30 rag. Drove a couple, but never owned a W Olds
    Polk SDA 2B's
    Carver TFM-45
    Sony X33ES
    Theater:
    Sony XBR-850b
    Denon 1709
    Rti-6 by 4
    Csi 3
    Paradigm PSW10
  • Any w30, hell I would settle for a 69 Hurst if I had too...lol.
