Shortening a Power Cord
kevhed72
in Electronics
I have a Panamax 4300 power conditioner with one of those waaaay too llong power cords. I would like to cut it down to 6 feet because I will never move it and baring it blowing up, never take it out of the HT rig. Before I crack this thing open, how difficult do you think this would be?
shouldn't be too difficult, however your not hurting anything either by leaving well enough alone. Pop the top and see how it's wired up inside.HT SYSTEM-
lsi 9's -
Piece of cake, if you know what you're doing.Political Correctness'.........defined
President of Club Polk -
Just cut the power cord to the length you need and install a good power plug. It should be easy to match up the wires from the plug and cable you cut off.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
helipilotdoug wrote: »Just cut the power cord to the length you need and install a good power plug. It should be easy to match up the wires from the plug and cable you cut off.
This is what I did to one of my power conditioners. I used a hospital grade plug and shortened the cord by several feet. It didn't do anything that I could detect soundwise but it did help cleaning the rat's nest of wiring. -
Shorting the cord should be as simple as walking.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
I could see myself with spiked hair after plugging the unit in.
Don't try shortening the cord while wearing high heels.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
Hahaha! I kept thinking she would make it to the end. NOPE! Hilarious.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Plug it in to an outlet, bypass the circuit breaker for said outlet with a 16 penny nail, cut the cord with a pair of side cutters, with the grips removed, after wetting your hands with salt water. Still more civilized than a pfb family Christmas.2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
Pardon me, more civilized than his relatives in Christmas2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
