Shortening a Power Cord
I have a Panamax 4300 power conditioner with one of those waaaay too llong power cords. I would like to cut it down to 6 feet because I will never move it and baring it blowing up, never take it out of the HT rig. Before I crack this thing open, how difficult do you think this would be?
    shouldn't be too difficult, however your not hurting anything either by leaving well enough alone. Pop the top and see how it's wired up inside.
    F1nut Posts: 52,145
    Piece of cake, if you know what you're doing.
  • Just cut the power cord to the length you need and install a good power plug. It should be easy to match up the wires from the plug and cable you cut off.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • motorstereo
    motorstereo Posts: 2,392
    This is what I did to one of my power conditioners. I used a hospital grade plug and shortened the cord by several feet. It didn't do anything that I could detect soundwise but it did help cleaning the rat's nest of wiring.
  • Shorting the cord should be as simple as walking.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    I could see myself with spiked hair after plugging the unit in.
  • DSkip wrote: »
    Don't try shortening the cord while wearing high heels.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Hahaha! I kept thinking she would make it to the end. NOPE! Hilarious.
    2 channel:
    Theater:
  • seabeerob213
    seabeerob213 Posts: 1,843
    Plug it in to an outlet, bypass the circuit breaker for said outlet with a 16 penny nail, cut the cord with a pair of side cutters, with the grips removed, after wetting your hands with salt water. Still more civilized than a pfb family Christmas.
  • seabeerob213
    Pardon me, more civilized than his relatives in Christmas
