Used speaker cables?
French_guy
in Speakers
Any website recommendation for used speaker cables? Not looking for anything fancy/high $$$, just some decent quality cables where I will hear real improvement compared to regular "Monoprice" type 12AWG cable......
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
No surround...yet
Well it's highly unlikely that you will 'hear' a difference with any reasonable cable.
Audioquest Rocket 33's will give you a little bump. Check Fleabay.
I noticed an improvement with Kimber over Monster.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
PM sentDan
You might also consider Douglas Cables. They are well made, sound amazing and won't break the bank.
http://www.douglasconnection.comThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Please send me a PM if you are interested in a pair of demo cables I'll be selling. Just give me an idea of what you want to spend and the length you need. I might just have the perfect pair for you
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
That was quick Doug... Lol!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
French_guy wrote: »Any website recommendation for used speaker cables? Not looking for anything fancy/high $$$, just some decent quality cables where I will hear real improvement compared to regular "Monoprice" type 12AWG cable......
www.usedcables.com
www.audiogon.com
www.hifishark.com
President of Club Polk -
Used cables is a wise choice, except don't think your going to spend the same as those basic Monoprice cables and get a big difference. Some brands to look for are Kimber, Audioquest, Reality cables, MIT, Acoustic Zen, Analysis Plus, Morrow, Harmonic technology, Cerious Technology, just to name a few as hundreds exist but those are some of the more popular brands.HT SYSTEM-
lsi 9's -
What about Cardas?RTiA5 + CSiA4 + Jamo SW410E
No surround...yet -
French_guy wrote: »What about Cardas?French_guy wrote: »What about Cardas?
Also a good brand. Except to my ears, the Cardas line doesn't shine until you get into their top tier cables.....or close to that. Same can be said for many brands though.
Most all brands have certain lines of cables, with each line improving on the previous. Some have a sweet spot in their line up, a line that represents the best sound for the buck. For instance, imho....MIT's shotgun series is their best bang for the buck. Acoustic zen Satori speaker cables and Matrix 2 IC's are their best bang for the buck. Analysis plus Oval 12's or 9's and crystal oval IC's....best bang for the buck. Kimber 8tc speaker cables and Hero IC's also a good bang for the buck. Morrow MA3, Just a few examples.
The lower lines in some of the brands can be just as awful as cheap home depot cables, and the highest lines....depending, may not offer that big of sound improvements over their mid-line stuff for the premium price. Generally speaking of course, not always the case.
A lot depends on your gear, system matching to the sound you prefer. Your not obviously going to stick 500 buck speaker cables on a set of 300 buck speakers. Know what I'm sayin' ?HT SYSTEM-
