5 verses seven
typonegative911
hello i got a harmon kardon avr 325 you can run five or seven channels its in a normal size living room do you think i should run it in just five or will seven make a difference thanks in advance.
Post edited by typonegative911 on
Where is your listening area relative to the back wall ?
punctuation always helps just kidding welcome to the forum
If your room is big enough and you can position the 7 speakers relative to the listening spot correctly, then by all means go with 7 speakers.Bob Mayo, on the keyboards. Bob Mayo. -
LOL... cut a fellow Buckeye some slack, will ya...
More later,
Tour...
Vox Copuli
Welcome to the forum.
"Normal" listening room is pretty vague. I have one rig in a 10x10 (with 8' ceilings) and one rig in a 15x18 (with 12' ceilings). The seating is also different. In the smaller room, my seat is pretty close to the back wall; whereas, in the larger room I sit on about midway for action movies and against the back wall for snuggly movies.
Then again, I just gave away my DD/DTS receiver so don't listen to me.Make it Funky!
