My new low cost system!
madmax
madmax Posts: 12,434
For whatever reason I decided I must have one of the Fiio X3ii portable players. It acts as a USB DAC as well. $200. Then after reading how a portable outboard headphone amp can increase the quality of sound of some headphones I picked up a Fiio E12 for $99 on sale. I mated with a pair of Polk Ultrafocus 8000 headphones I picked up at the last 50% off sale for $125. Oh, and had to buy a micro-SD card for about $50 and a USB wall charger for $7. So the system total was $481.
This little system really synergizes and each piece seems to work exceptionally well. Add about $100 for some DSD downloads and the sound is awesome! I could actually live with this as my only audiophile adventure if for some reason I couldn't have or afford a full home system.
I am very impressed!
Later on I picked up a pair of HiFiMan Songbird IEMs for $200 and they are pretty awesome as well, much better than the Shure $99 ones I used to have.
madmax
Vinyl, the final frontier...
  • voltz
    voltz Posts: 5,384
    Hey Max
    how do you stack it? I seen they had a HS12 stacking kit but couldn't see one for sell.
    I have a Ipod classic and a JDS labs C5 I like but it only does FLAC.
  • madmax
    The E12 amp came with a few black rubber bands, about 1/4" wide which worked well for stacking. There was also a silicon pad which you place between the two to keep them from squirming around and scratching each other.
  • RamZet
    RamZet Posts: 792
    Awesome stuff, right?
    I picked up the E07K and I paired it with my cellphone for mobile use. ( the LG G3 plays back FLAC and will even label the Flac files as "HiFi").
    For desktop use I also picked up the Fiio E09K Desktop Amp/dock. I am very pleased with all the Fiio gear, its well priced and built well. Packaging was nice too.
    https://scontent-yyz1-1.xx.fbcdn.net/hphotos-xpt1/v/t1.0-9/10868178_901130389905580_8846835877644989050_n.jpg?oh=8377220ea18f7918197db7e378afda13&oe=56BF9FC3
    B&W CM9Classé Sigma
    gudnoyez Posts: 8,075
    I have the JD labs C5 an iPod classic and a few iPod touches with Sennheiser and Polk headphones and sometimes feel the same way at times I prefer to listen to those over my 2 channel rigs, so I can agree with you.
  • madmax
    A few weeks ago I tried a pair of Audio Technica M50x headphones with the Fiio. With the polk headphones the external amp made a huge difference and was almost a requirement while the M50x seems perfectly content with the built in amp.
    Not to ever leave anything alone I went ahead and tried a Cayin N5 digital audio player for $350 vs $200 for the Fiio. The N5 does everything just a little better and the internal amp drives the polks pretty well. Considering the external amp is not really a requirement with the N5 it is pretty much a wash as far as cost goes. I would recommend either setup although I prefer the sound of the N5 a little more. With the right headphones the Fiio could turn out to be cheaper and smaller if you don't need the external amp.
  • French_guy
    madmax wrote: »
    How did you like the M50x with the Fiio X3 2nd gen? Trying to find good headphones (will be my 1st one)
    RTiA5 + CSiA4 + Jamo SW410E
    Yamaha TSR-700 (equivalent to RX V6A)
    No surround...yet
  • madmax
    It was great! Then I switched the earpads to the velvet ones and they didn't sound nearly as good with the fiio. The original earpads were much better with the fiio. Very pleasing sound.
