Testing a set of Monitor 10B's
I'm new here. Found you when I began looking for info on the Monitor 10B speakers. I originally bought these in 1980 something, used them and loved them until I went to digital with a home surround system. I just got them back! I'm wanting t know how to "test" them and check them out for before I start using them again. How and what do I do make sure they are performing well?
    F1nut Posts: 51,880
    Hook them up, then listen.
  • Nightfall
    Nightfall Posts: 10,083
    Press gently on the 6.5" drivers and make sure you don't hear and feel any scratching noises or worse, they're frozen and don't move at all.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • THANKS for the tips on how to check out a pair of old speakers. I think that to hook them up and listen to them was a brilliant. They seem to check out and sound amazing.
    F1nut Posts: 51,880
    B)
