Opinions on Marantz Integrated Amp PM7000
teamjhertz
I have a set of LSi15s. I have been looking at an economical integrated amp option and this one came up in my radar. Does any one have any experience or other recommendations around $300 used?
My other option would be to purchase a two channel amp and use my preouts on either my SC05 or an older Denon AVR886
I had them hooked up to a XPA3 in the past and is pretty good for HT. I am looking to use the speakers for 2 channel now.
Thanks for the help.
I have not heard the Marantz, but man if you could save up an additional $200 the options are greater.
That is not out of the question. What would you recommend?
I like the idea of a brand new Yaqin integrated in the $500 range. Don't let the 40 or 50 watts fool you.
If you stay in the $300 range, NAD is a solid choice. -
Thanks for the advise
He's running the LSi15's Skip2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »He's running the LSi15's Skip
I've had that yaqin integrated tube on my radar for a while. Man is it tempting!2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Do you not think the Ampino could handle it, or do you think it would be a bad tonal match?
Tonal match would be fine, it's the power LSi require2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Do you think I would be better off looking for a standalone amp since the load is tough and would require a higher priced integrated amp?
Not that it matters a whole bunch in this hobby, but the ampino is not much of a looker. Guess that is a matter of opinion though...looks can be deceiving.
