Opinions on Marantz Integrated Amp PM7000
teamjhertz
teamjhertz Posts: 363
edited December 2015 in Electronics
I have a set of LSi15s. I have been looking at an economical integrated amp option and this one came up in my radar. Does any one have any experience or other recommendations around $300 used?
My other option would be to purchase a two channel amp and use my preouts on either my SC05 or an older Denon AVR886
I had them hooked up to a XPA3 in the past and is pretty good for HT. I am looking to use the speakers for 2 channel now.
Thanks for the help.
  • Conradicles
    Conradicles Posts: 6,373
    I have not heard the Marantz, but man if you could save up an additional $200 the options are greater.
  • That is not out of the question. What would you recommend?
  • Conradicles
    I like the idea of a brand new Yaqin integrated in the $500 range. Don't let the 40 or 50 watts fool you.
    If you stay in the $300 range, NAD is a solid choice.
  • Thanks for the advise
    txcoastal1 Posts: 13,519
    He's running the LSi15's Skip
  • mikeyb128
    mikeyb128 Posts: 2,885
    txcoastal1 wrote: »
    I've had that yaqin integrated tube on my radar for a while. Man is it tempting!
    2 channel:
    Theater:
    DSkip wrote: »
    txcoastal1 wrote: »
    Do you not think the Ampino could handle it, or do you think it would be a bad tonal match?
    Tonal match would be fine, it's the power LSi require
  • Do you think I would be better off looking for a standalone amp since the load is tough and would require a higher priced integrated amp?
  • Conradicles
    Not that it matters a whole bunch in this hobby, but the ampino is not much of a looker. Guess that is a matter of opinion though...looks can be deceiving.
