Sansui 7070 - Nice!
gmjungbluth
Wanted to share- I just found a Sansui 7070 receiver at a local record store. It’s in pretty good shape – everything is there and it sounds really really good. The lamps in the front didn’t all light up until I banged on the top of the unit. It turns out that the light board is notorious for poor solders. After about 10 minutes of reheating all the solder joints on the board I got all but one lamp to glow. Now it looks great.
I replaced the peeling vinyl wrap with some leftover cherry veneer from my Polk Monitor 7 project- now it looks really good.
I wouldn’t have bothered if this thing didn’t sound so damn good. I hooked it up to my Polk Lsi7s and was absolutely amazed – this receiver sounds clear, clean, and amazing pleasant. And it has the current to drive some pretty power-hungry loads. I'm definitely going to play with this one for a while!
I posted pictures on my blog - www.silverfacestereo.com
HT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100
Marantz NR-1403
Front: Klipsch CF-4
2Ch:
Living Room:
Harman Kardon 3380
Bedroom:
Polk PSW10
KLH Model 6,
Polk LSI7
NAD 7100
Congrats. Those Sansui ball busters sound pretty sweet dont they. They sure did make em good. EnjoyRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Great graphic! The 7070 sure does look nice. And I'm impressed with the power to the Lsi7s - I was not expecting them to pair as well as they did.HT System:
Marantz NR-1403
Front: Klipsch CF-4
2Ch:
Living Room:
Harman Kardon 3380
Bedroom:
Polk PSW10
KLH Model 6,
Polk LSI7
NAD 7100 -
I have a 9090 and love it. good read here
https://medium.com/cuepoint/how-a-digital-guy-fell-in-love-with-a-vintage-stereo-receiver-3bc132a347d7#.v6i0m3qam -
Looks great and glad your enjoying vintage HiFi
I have a 9090 and wouldn't part with it.
P-man
Because I am The Pumpkinking
Very nice, there's a ton of information on line on how to service those receivers, they sound much better and safer when properly set up and running in spec.
Service manuals are available for free download at hi-fi engine web page. It's recommended to check the idle current and DC offset balance is recommended.
You may be able to do it yourself. If your good with soldering, it wound be a bad idea to re flow suspicious solder joint and replace electrolytic capacitors that show sighs of failure, for example, caps showing shrinked sleeve, bloated, etc...
Have fun
