Carver and Polk synergy
honestaquarian
honestaquarian Posts: 3,275
edited June 2006 in 2 Channel Audio
I KNOW there are others out there who like the way Carver electronics sound with Polk speakers.I want to hear from you.I ESPECIALLY like the way that the TFM series of amps with the SIlver Seven vacuum tube transfer function sound with Polks that have the SL-3000 tweeters.As well as the RD-0194's.Any comments?Any other opinions?:cool:
«13
  • madmax
    madmax Posts: 12,434
    edited June 2006
    I thought the carver silver 9t's sounded ok with the SDA's but in the end I sold them. A little too sterile for me. They are clean powerhouses for sure though! In the same price range I much prefer soundcraftsmen amplifiers or tubes.
    madmax
    Vinyl, the final frontier...
  • SDA SRS 1.2
    SDA SRS 1.2 Posts: 255
    edited June 2006
    I always enjoyed my TFM-45, C-16, and TX-11b with the SDA's. The Sunfire works well with the SDA's also. :)
    Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
    Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
    Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD! :) )
  • honestaquarian
    edited June 2006
    I have a C-19 preamp myself.When i FINALLY decided to go full 5.1 i pulled it out and put in a Parasound AVC-2500.OY VAT A DIFFERENCE!Now i have no use for my C-19(which had been giving me trouble ANYWAY) and the TX-11A.
  • ohskigod
    ohskigod Posts: 6,505
    edited June 2006
    my carver 4.0t (same as the tfm 42/45) allways sounded good on polk speakers. I used them with sda's, RTA12's, Lsi9's and 15's. some will argue better, especially based on preference, but you certainly cant go wrong.
    my 4.0t currently drives the LSi15's in my HOme Theater set up, giving them 500 watts of power the LSi's crave so much. simply put, movies rock in my house!
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • honestaquarian
    edited June 2006
    One of the two most realistic sound recreations that i have EVER heard was with a pair of Polk RTA-12's(the last of the line with the SL-2000 tweeters)and a Carver M-4.0t amp.It was being driven by a Carver sonic holography preamp(i cannot remember which)and a Carver SD/A-490T cd player.I was listening to a Telarc cd and the orchestra was laid out before me!
  • Airplay355
    Airplay355 Posts: 4,298
    edited June 2006
    I used a Carver m.05t with my Lsi's and my SDA's. Great powerhouse amp, but in the end, my musical fidelity integrated sounded noticeably better. Classic case of you get what you pay for I guess. I could have bought 4 of the carver amps for what I paid for the integrated :)
  • scottwilson999
    scottwilson999 Posts: 2
    edited June 2006
    I am new to the forum and new to Polk use. I have used Infinity products for years--this may well brand me a heretic, but I have recently purchased and received what I nearly bought many years ago: the RTA-15 model. I debated between it and the Kappa 8, and I ended up going with the Kappa 7 for shipping reasons.
    Now, I finally have the RTA 15s by which I was always intrigued. One of the tweeters is blown, and I have ordered original SL-3000s at $100.00 each--am I paying too much?
    I am running a Carver HR-752 receiver with the pre-outs plugged into a TFM-42--without the wonderful vu meters of the TFM-45.
    Thus far I am very impressed, even without the second tweeter running as it should.
    (By the way, when I moved the wires connected to the SL-3000 about, having removed the tweeter to inspect it only to find its untimely demise, suddenly midrange sound came into play where I had only heard bass before--a short in the wiring perhaps--can anyone explain? No highs or midrange, play with wire: midrange and bass, but still a very dead tweeter--short somewhere in addition to dead tweeter?)
    My brother always had the jr. SDA with the stands, and he still swears by Polk and the SDA phenomenon. I am running Carver's sonic holography, so I do not require the SDA.
    One other thing had always troubled me. It was the use of passive radiators. They seem like so much audio alchemy. How can they possibly work? Dammit, they shouldn't work, but hearing them, feeling them, I believe they do. Am I the victim of some sonic spell? There is no power, no voice coil! Sound pressure trapped in the cabinet? Did Polk make some Faustian bargain for yet another inexplicable phenomenon?:confused:
    F1nut Posts: 52,407
    edited June 2006
    Welcome!
    Polk no longer sells the SL3000, but they have a replacement, the RD0198-1. The new tweeter is silk vs. the metal dome and sounds much better. It's best to order two for matching purposes.
    You probably have one or more loose connections in the one cabinet. It would be worthwhile to open it up to check.
    FYI, Carver's sonic holography is similar to the SDA technology, but most agree that SDA is better.
    Enjoy your new speakers.
  • honestaquarian
    edited June 2006
    The main differences between Carver's Sonic Hologram Generator and Polk's SDA(Stereo Dimensional Array)is the fact that the Carver is an active electronic system VS Polk's Passive acoustic approach.Also The later SDA's only ran the interaural crosstalk distortion cancellation signal from 200 hz to 1000 hz.The Carver runs it full range.I used to own a pair of RTA-15TL's and dearly miss them.Even without any kind of crosstalk cancellation they can throw a 3D holographic soundstage.Oh and the Passive radiators are driven by the air inside the cabinet which is excited by the movement of the midwoofers.Those big center caps are for resonant tuning to certain bass frequencies to help deliver the low end.In the case of the 15's QUITE effectively.Welcome to Polk and the forum.I see that it has been quite a long time in coming!!!!!!!!
    Carlton
    P.S.I always thought the Infinity sound was very similar to Polk in most respects.I just latched on to Polk about twenty years ago and have never gone back.Oh well ya gotta make choices!
  • honestaquarian
    Currently own a pair of SDA-SRS 3.1TL's being driven by a Sunfire Cinema Grand Signature. WONDERFUL sound!! Bi-wired.
  • Unknown
    edited December 2015
  • honestaquarian
    Well I can do that since it's a thread that I started 9 years ago!! :D
    I hadn't been on here since then............
  • honestaquarian
    That is with the SDA-1C's and CS-400 which I am selling in another thread.
    Now I have the SDA-SRS 3.1tl's and a CS-1000p
    All driven by the same Sunfire Cinema grand Signature amp.
    (you can just see the LED's on the M-400a amp behind the Blu-rays.Which drives the height channels visible in the upper pic)
  • honestaquarian
    edited May 27
    Well I couldn’t help meself.
    My old boss from when I used to sell stereo equipment sends me a link to an auction site in Virginia where these three Carver TFM-35 amps were up for auction.
    So I waited and watched.
    Then registered.
    Then waited until literally the last minute and placed a max bid.
    No surprise suddenly a bunch of other bids came in at the last minute!
    I won!
    I took a huge gamble and wound up getting three working TFM-35 amps for the price that one would go for on eBay!!
    Not a fan of the blue LED meter light replacements. Which I only discovered after I got the amps and turned them on.
    They all work though and I have integrated them into both systems. Two in the living room driving my front and now rear height speakers for DTS X, Dolby Atmos, Auro 3D.
    One in the bedroom replacing a TFM-25 with a major hum problem in one channel.
    That one is driving a pair of Polk RT55’s that I upgraded to “i” status by changing out the tweeters (that and the blue woofers was the only difference between the 55’s and the 55i’s)
    I didn’t think there would be much of a difference in the sound, but there definitely is and I am very happy. 😊
    Now I need to get some canned air and contact cleaner and clean the amps out as they are very dusty and the gain controls are a little staticky.
  • Jetmaker737
    Jetmaker737 Posts: 1,147
    Only a few days until the 20th anniversary of this thread, lol
    msg Posts: 10,650
    I truly love that we don't lock threads here :)
    Hey Carlton!
    Nice pickups, good seeing you excited about the score!
    xschop Posts: 5,820
    edited July 30
    Then registered.
    I won!
    I guess Phase Linear and Polk will be an awesome combo then?
  • honestaquarian
    I honestly have never heard a Phase Linear amplifier.
    Funny thing is I always thought the TFM series Carver amps (the ones with the Transfer Function modified sound like the Carver Silver Seven Tube amplifier) sounded best with Polk loudspeakers.
    treitz3 Posts: 20,358
    That one, and perhaps the M-500t. BITD, it was seemingly commonplace knowledge that Polk and Carver gear paired well together.
  • honestaquarian
    If that was the case then I never saw anybody talking about it. Which is why I started this thread long ago.
    xschop Posts: 5,820
    Ive heard a TFM on some stock 11Ts.. Not bad at all.
    F1nut Posts: 52,407
    The TFM amps sound nothing like the Silver Seven tube amps.
  • honestaquarian
    xschop wrote: »
    I've heard the TFM amps with the RTA-15tl's.AMAZING
    xschop Posts: 5,820
    Will be joining the club soon...
    xschop Posts: 5,820
    Started a @VSAT88 inspired XS restomod WOPL400. B)
    SCompRacer Posts: 9,395
    edited August 1
    Nice score! I had a 35/35X and a 45 back in 2005 IIRC. Gotta love the swinging needles.
