Inexpensive IC's
  • Thanks for the awesome cables
  • I also bought BJC at 1mt. I forgot how much they were but if I could afford it so can you. I originally went w/ Frank's Signal Cable and either because of a defect or my heavy handness an end fell off in my hand. It was way to late to complain so I went the Blue Jean route. I will say their ends are large and are compression fit w/ no heat shrink sleeve. I think they were $31.50 +shipping. The top pair in the paste.
    http://www.bluejeanscable.com/store/audio/index.htm
  • Great inexpensive cables here. http://www.amazon.com/StarTech-com-AUDIORCA6-Premium-Stereo-Audio/dp/B00027BVKE
    Don't judge this one based on price. It's a simple flexible directionally shielded cable, that sounds fantastic. I actually prefer it now to my lc1's. Gonna be ordering more :)
  • Speedskater
    Speedskater Posts: 495
    edited December 2015
    A non-directional coax is a better plan.
    msg Posts: 10,452
    How so? Does that mean the shielding is terminated on both ends?
    tonyb Posts: 33,075
    Not necessarily, too many variables to make that call. I wouldn't shy away from either design. It's the sound that matters, and how nice it plays with your associated gear.
  • msg wrote: »
    With coax the shield has to be connected on both ends. The shield on coax is the negative conductor.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
    msg Posts: 10,452
    Ohhh, coax. Duh, I was thinking IC. What is the reason again for terminating IC shielding on one side only?
  • It's an idea borrowed from balanced interconnects. Under some circumstances the shield is only connected at the send end (with maybe a hybrid connection at the receive end).
    Now in short (less than 3 meter/10foot) RCA unbalanced interconnects it won't matter. But in long interconnects a good coax may have up to 20 dB less background noise.
