Polk SDA 1C Mod Progress
Glad you're pleased Steve, and welcome to the SDA Family. The new Caps will need a minimum of 200 hours burn-in before they really sound their best. Just play them as you normally would. There may be subtle changes along the way, but everything will settle in and get better.
Also, double check all your screws, and do the air leakage test.
BTW, do not over-tighten the Tweeter's screws. The plastic bezel is easily deformed.Home Theater/2 Channel:
dhsspeakerservice.com/ -
I am pleased as punch and couldn’t of done it without you Dave. If your ever in the Gainesville, FL area I owe you a beer or twelvePolk SDA 1C Upgraded, Eastern Electric Minimax Supreme DAC, Parasound HCA 1200ii, Belles 21a Preamp, Rotel RSX-1056, Matricom G Box Q, Blue Jean & Signal Cable interconnects, Sonographe SG-3 TT, Panamax M4300-PM
Was my pleasure Steve. You did all the bull work, my part was easy.Home Theater/2 Channel:
These old SDA's to this day still have a lot to offer. I like mine so much I built my new system around them.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
