What's on your rack?
What this boils down to is that my AVR and amps are now separate from the rest of the AV equipment on my rack, so I'm wondering what to get to fill the voids. Currently I have a power conditioner, htpc, and ps3. I'm thinking about adding a standalone bd player.. But I am not sure where to start.
So what do you guys think and what's on your rack?
Too many good quotes to list..waiting for some fresh ammo. :)
  • Nightfall
    Nightfall Posts: 10,073
    edited November 2015
    Turntable, phono preamp, B&K 2 channel preamp, B&K 2 channel amp, Yamaha Aventage AVR, Xbox One, PS3, 2 Monitor 5's as a center channel, TV, and a broken Yamaha CA-1010.
    Post edited by Nightfall on
    afterburnt wrote: »
    Village Idiot of Club Polk
  • mikeyb128
    mikeyb128 Posts: 2,885
    On my rack Upstairs:
    Panamax m5400pm, marantz 7702, Sunfire tga 7401, Apple TV, oppo 105D, Xbox 360, and on the very top a lsim 706c.
    And Downstairs: 2x B&K reference s2 mono blocks, teac tn300 TT, benchmark dac2L, and a phono pre coming soon.
    Can't forget the friggen dust. So dry here, feel like a need to dust twice a day.
    2 channel:
    Theater:
  • Irrenhaus
    Irrenhaus Posts: 1,082
    On this one Nunc PC, DAC, headphone amp, tube pre, amps, passive pre for Sub, cable modem, router and a cable mess.
    Also dust, but try to cleaning often.
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • warren
    warren Posts: 756
    Oh, the a.v. racks, I thought the soft ones were back, oops!
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
  • villian
    villian Posts: 412
    xcapri79 wrote: »
    What does your rack look like?
    Pretty barren..
    (My theater is currently torn apart.. Ignore the mess)
    All the power amps are up front with the avr now
  • leftwinger57
    Another Adcom dude I see. Here's my rack face GFA555 among sorted other gearkzueaile6ocp.jpg
  • tratliff
    tratliff Posts: 1,670
    Here is my rack. Just finished it up about a month ago. I only have one shelf empty and it seems to collect odds and ends. Not much room left for additional equipment and I am glad. Enough is enough. At least for now. :)
    2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Silver 4+ Interconnect Cables, AudioQuest Niagara 7000 w/Dragon and Hurricane Power Cables
  • Mikey081057
    Mikey081057 Posts: 7,127
    Garage | Polk Monitor 5B's
  • villian
    villian Posts: 412
    Man, that Panamax is pretty! @Mikey081057 Also, how do you like that AV7702?
  • Mikey081057
    The AV 7702 is fine... eventually I will get my ceiling speakers rigged... Panamax or > is a must here in the lightning capital of the world. Made it thru 1 season no issues...
  • voltz
    voltz Posts: 5,384
    that is some sweet setup's :)
    treitz3 Posts: 18,405
    36DD in "Very Sexy" by Victoria's Secret. My other rack is just as beautiful.......and that one, I might share.
  • Willow
    Willow Posts: 10,884
    I think your rack needs a little lift, you've got some sagging going on, at least in the top half.
  • mikeyb128
    Willow wrote: »
    Maybe it's due to age :open_mouth:
    2 channel:
    Theater:
  • Mikey081057
    mikeyb128 wrote: »
    Willow wrote: »
    It's ok for a rack to sag a little... just as long as it doesnt flop around with the ceiling fan on
  • leftwinger57
    Forget about that black lacquer thing you saw before. I now have a stunning and very sturdy Sanus 6 shelf rack that I got off C/L for $60.udctxhro43cb.jpg
  • MrBuhl
    MrBuhl Posts: 2,419
    ^^ Stolen Sanus! ^^ that's a great deal!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • Gatecrasher
    Gatecrasher Posts: 1,550
    Hey Villain. Your setup and your SRTs look nice but what's up with the grills? It looks like they are both from the same side speaker. Not opposite from each other. Did they come that way?
  • villian
    villian Posts: 412
    Kinda sorta. Short answer, yes. Long answer, there's some pinholes opposite of where the badges are currently placed..so I suspect that they were placed on the other sides originally and moved. Not sure why, or how they ended up the way they are, but I always just figured it was correct as is. I take it that yours are different?
    I think I just got a great idea for a new thread btw! Thanks for the inspiration!
  • polk500
    polk500 Posts: 1,171
    My home made rack, I didn't bother to apply a finish as it sit in a small closet. It also has wheels so I can access the back.
    Cheers,
    Roger
  • xjghost
    xjghost Posts: 1,085
    edited December 2015
    tratliff wrote: »
    I like that. I'd like to get a new stand for the den the one I have is too small with only 3 shelves. Did you build that?
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • tratliff
    xjghost wrote: »
    tratliff wrote: »
    No, it is 3 Sanus Euro racks with optional shelf spacing. Then a custom piece of granite for the top. The thing is rock solid. No pun intended.
  • Mike Reeter
    Mike Reeter Posts: 4,314
    Great looking gear and setups, I have a DYI rack that was a "double wide" and recently made some changes to a taller "singlewide" to accommodate some different gear.
    Before
    After
