Are RT35 and RT35i the same thing?
Hi. I'm on a mission to put together a cheap but good HT system. I settled on Polk RT35i for the front, and turned to e-bay. I found some promising listings, but on the close-up photos of the back labels, some say RT35, and others RT35i. Are they different models? Different versions of the same model? Is there a sound difference? Thanks for any info.
Best Answer
  • honestaquarian
    honestaquarian Posts: 3,260
    Answer ✓
    Actually the tweeter in the RT-35i is an SL-6506.The tweeter in the RT-35 is an SL-6502.Yes the only difference in the woofers is the color to differentiate the two.I own a pair of RT-35i's and needed a tweeter.I got this information directly from Polk when I called.The same goes for the RT-55 and RT-55i.As well as the CS-400 and CS-400i center. So I wound up eventually changing out the tweeters in my 55's and my CS-400. The SL-6506 is a better tweeter! I also changed the tweeter in my RT-1000p to kind of make it an RT-1000i ;)
    (*NO such a model never existed in production.It does in my home theater now!*)
Answers
