Kendeil Capacitor Question/Help
F1nut
Does anyone have any experience with Kendeil K05 capacitors? I'm looking for 6800uF 100V, but 8200uF 100V would work as well. I was hoping to use Mundorf M-Lytics, but they do not come in either of the values I can use. Nichicon KG's would have worked, but again not available in the values I need. So, I've been hunting around the net all night and came up with the Kendeil's, which apparently are used in Quad, Naim and some Krell amps. Reviews however, are not easy to come by, but those that I've found are favorable comparing them to the Mundorf's, which I know are excellent.
Any feedback or suggestions are welcome, but I'm only looking for audio grade caps.
They are also used in my tube amps, and I have zero complaints. I would use the again in a heartbeat.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
High praise indeed John, thanks.
Do you remember where you bought them?Political Correctness'.........defined
President of Club Polk -
Ebay... I figured they had to be better than the Panny's and the others Bob was using. They were not cheap, but they do seem to pack a punch. I remember Bob accidentaly using his fingers to discharge the caps when we were tweaking my amps on his bench and I thought I would be needing to do mouth to mouth.(EEEWWWW).
Whatever was good enough for the likes of Pass and Krell is good enough for me.
I'm sure you did but on the chance that you didn't...
http://www.kendeil.com/
Name: I.C.T. Power USA Inc.
City: 60174 Saint Charles Illinois
Type: Distributor
in my neck of the woods no less -
Thanks John and yeah that would have been EEEWWWW!
Thanks Ivan, I did find that distributor info and also the info for a US sales office, but I haven't called either yet. Near as I can tell though, no one carries them here. I did find a seller on eBay who is in Turkey of all places that has what I need, just not so sure if there are real Kendeil caps or not. I will say his feedback is excellent, so that's encouraging.Political Correctness'.........defined
@F1nut
Enough chit chat...whatcha brewing or rebuilding? Inquiring minds want to know2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
You know me, I like to finish a job before talking about it.Political Correctness'.........defined
txcoastal1 wrote: »
I'm offended... -
ReportedHome Theater/2 Channel:
dhsspeakerservice.com/ -
Any other input?Political Correctness'.........defined
Kendeil capacitors are highly rated. Cornell Dubilier is another choice I've seen used at diyaudio.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I forgot, Fred put me on to United Chemi-Con. I used their KMH 105c series in the Krell KSL pre I recapped. You know Fred wouldn't suggest anything so-so. I haven't looked to see if they have the values you need in this series.
http://www.digikey.com/catalog/en/partgroup/kmh-series/3674
Thanks Rich, I'll look into the United Chemi-Con KMH 105c series. I've already ruled out Cornell Dubilier though.Political Correctness'.........defined
Jesse if you REALLY wanna know about those caps. You know who you MUST ask here. He'll know fo sho! lol--Gary--
Perish the thought, I'd have to be a lunatic.Political Correctness'.........defined
But it's OK to poo-poo on your own thread2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I have Raging rectal itch... Sorry, off topic. -
Spraying now, cooling as we speak...Ahhhh -
Just don't light your **** afterwards...Post edited by [Deleted User] onThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
