Kendeil Capacitor Question/Help
F1nut
F1nut Posts: 51,776
edited December 2015 in DIY, Mods & Tweaks
Does anyone have any experience with Kendeil K05 capacitors? I'm looking for 6800uF 100V, but 8200uF 100V would work as well. I was hoping to use Mundorf M-Lytics, but they do not come in either of the values I can use. Nichicon KG's would have worked, but again not available in the values I need. So, I've been hunting around the net all night and came up with the Kendeil's, which apparently are used in Quad, Naim and some Krell amps. Reviews however, are not easy to come by, but those that I've found are favorable comparing them to the Mundorf's, which I know are excellent.
Any feedback or suggestions are welcome, but I'm only looking for audio grade caps.
    nooshinjohn Posts: 25,926
    They are also used in my tube amps, and I have zero complaints. I would use the again in a heartbeat.
    F1nut Posts: 51,776
    High praise indeed John, thanks.
    Do you remember where you bought them?
    Ebay... I figured they had to be better than the Panny's and the others Bob was using. They were not cheap, but they do seem to pack a punch. I remember Bob accidentaly using his fingers to discharge the caps when we were tweaking my amps on his bench and I thought I would be needing to do mouth to mouth.(EEEWWWW). :D
    Whatever was good enough for the likes of Pass and Krell is good enough for me.
    pitdogg2 Posts: 27,050
    I'm sure you did but on the chance that you didn't...
    http://www.kendeil.com/
    Name: I.C.T. Power USA Inc.
    City: 60174 Saint Charles Illinois
    Type: Distributor
    in my neck of the woods no less
    F1nut Posts: 51,776
    Thanks John and yeah that would have been EEEWWWW!
    Thanks Ivan, I did find that distributor info and also the info for a US sales office, but I haven't called either yet. Near as I can tell though, no one carries them here. I did find a seller on eBay who is in Turkey of all places that has what I need, just not so sure if there are real Kendeil caps or not. I will say his feedback is excellent, so that's encouraging.
    txcoastal1 Posts: 13,513
    @F1nut
    Enough chit chat...whatcha brewing or rebuilding? Inquiring minds want to know
    F1nut Posts: 51,776
    You know me, I like to finish a job before talking about it.
    You suck ;)
  • ken brydson
    ken brydson Posts: 9,003
    txcoastal1 wrote: »
    You suck ;)
    I'm offended...
  • westmassguy
    westmassguy Posts: 6,850
    Reported
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    F1nut Posts: 51,776
    Any other input?
    SCompRacer Posts: 9,112
    Kendeil capacitors are highly rated. Cornell Dubilier is another choice I've seen used at diyaudio.
    I forgot, Fred put me on to United Chemi-Con. I used their KMH 105c series in the Krell KSL pre I recapped. You know Fred wouldn't suggest anything so-so. I haven't looked to see if they have the values you need in this series.
    http://www.digikey.com/catalog/en/partgroup/kmh-series/3674
    F1nut Posts: 51,776
    Thanks Rich, I'll look into the United Chemi-Con KMH 105c series. I've already ruled out Cornell Dubilier though.
  • halo71
    halo71 Posts: 4,632
    Jesse if you REALLY wanna know about those caps. You know who you MUST ask here. He'll know fo sho! lol
    --Gary--
    F1nut Posts: 51,776
    edited January 2016
    Perish the thought, I'd have to be a lunatic.
    nbrowser wrote: »
    Just don't go raging away Jesse.
    But it's OK to poo-poo on your own thread
  • ken brydson
    nbrowser wrote: »
    I have Raging rectal itch... Sorry, off topic.
  • lightman1
    lightman1 Posts: 10,796
    nbrowser wrote: »
    WD40 my friend. Cleans that up real nice.
    OK bye.
  • ken brydson
    lightman1 wrote: »
    nbrowser wrote: »
    OK bye.
    Spraying now, cooling as we speak...Ahhhh
    edited January 2016
    Just don't light your **** afterwards...
