Burning DVDs on the PC: The Sequel
exalted512
Im back trying to burn DVD back-ups again
ive pretty much figured out, if i want to do this--im going to have to buy some software
i was told if you use DVD shrink and have Nero, you just click once and wait for it to burn
is that true?
nadams also mentioned DVD-X-Copy
i found this
is it worth the price you pay there?
or is DVD shrink just as good for free?
also, is there a certain Nero version i should be looking for?
if it matters, the DVD burner only burns DVD+R
thanks
-Cody
is that true?
i found this
thanks
-Cody
also, what about DVD Decrypter..what exactly does that do?
its free as well
http://www.dvddecrypter.com/index.php?act=download
DVD shrink now gets the thumbs-up from me. DVDXCopy was ruled to be illegal and you should no longer be able to buy it. DVD Shrink is free, and yes, if you have Nero, it integrates right in.
My one suggestion with DVD shrink is to take as much of the stuff that you don't need out, so that the compression will be less. The less compression, the better the video and sound quality. (IE- remove second language tracks, or audio tracks that you don't need)Ludicrous gibs! -
Random curiousity......what makes one DVD copying program illegal and others not?Originally posted by nadams
DVD shrink now gets the thumbs-up from me. DVDXCopy was ruled to be illegal and you should no longer be able to buy it.comment comment comment comment. bitchy. -
*shrugs* beats me... You can read about it on www.321studios.com
I don't know that it was actually ruled illegal... I think they just gave up because they ran out of money to fight the charges.Ludicrous gibs! -
Because some are commercially sold, and burning dvd movies is illegal, (ie: copyrighted) so they get banned... the rest are software developers who distibute it free and can't be governed becuase they arent chargeing, plus they cant find them or what not... Basically, if you make the software and sell it to the public you have to follow the rules.. If your making software in your house and giving it away... whos gonna ban ya... Nero will not burn copy right dvd's....MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
ive been told people have no problem with DVD shrink and Nero?Originally posted by faster100
i think im just going to get Nero and try it with DVD shrink
Sonic=sucks
I had a problem with the newest version of nero and dvdshrink 3.2. I went back to Nero 6.0.0.9 and had no problem. As was said earlier, I find it best to keep the compression above 70 percent. DVDshrink decrypts then burns. Had no issue with any dvd using the 2Matthew
Sometimes the road less traveled is less traveled for a reason
HT
Yamaha RX-V2500
CS400-Center
SDA 1A-Mains
RT20-Surround
None right now-Rears
SVS 20-39PCi
Infocus IN72 -
You don't need to compress anything with DVD shrink. First click on re-author and drag the main movie to DVD structure. Then click on compression and if it still shows less than 100%, remove the unnecessary soundtracks and only leave 5.1 DTS or DD. If that still doesn't do the trick, click on the icon with two opposite arrows, that will allow you to specify which chapters to copy. This will allow you to divide the movie into two discs, f.e. chapters 1-10 into disc 1 and 11-20 to disc 2.
BTW, burning with DVD Shrink is slow and also a memory hog. Put the movie into an image and burn the image with Nero.
