Burning DVDs on the PC: The Sequel
exalted512
exalted512 Posts: 10,735
Im back trying to burn DVD back-ups again
ive pretty much figured out, if i want to do this--im going to have to buy some software
i was told if you use DVD shrink and have Nero, you just click once and wait for it to burn
is that true?
nadams also mentioned DVD-X-Copy
i found this
is it worth the price you pay there?
or is DVD shrink just as good for free?
also, is there a certain Nero version i should be looking for?
if it matters, the DVD burner only burns DVD+R
thanks
-Cody
  • exalted512
    edited September 2004
    also, what about DVD Decrypter..what exactly does that do?
    its free as well
    http://www.dvddecrypter.com/index.php?act=download
    -Cody
  • nadams
    nadams Posts: 5,877
    DVD shrink now gets the thumbs-up from me. DVDXCopy was ruled to be illegal and you should no longer be able to buy it. DVD Shrink is free, and yes, if you have Nero, it integrates right in.
    My one suggestion with DVD shrink is to take as much of the stuff that you don't need out, so that the compression will be less. The less compression, the better the video and sound quality. (IE- remove second language tracks, or audio tracks that you don't need)
    Ludicrous gibs!
  • brettw22
    brettw22 Posts: 7,623
    Random curiousity......what makes one DVD copying program illegal and others not?
  • nadams
    nadams Posts: 5,877
    *shrugs* beats me... You can read about it on www.321studios.com
    I don't know that it was actually ruled illegal... I think they just gave up because they ran out of money to fight the charges.
    Ludicrous gibs!
  • faster100
    faster100 Posts: 6,124
    Because some are commercially sold, and burning dvd movies is illegal, (ie: copyrighted) so they get banned... the rest are software developers who distibute it free and can't be governed becuase they arent chargeing, plus they cant find them or what not... Basically, if you make the software and sell it to the public you have to follow the rules.. If your making software in your house and giving it away... whos gonna ban ya... Nero will not burn copy right dvd's....
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • exalted512
    ive been told people have no problem with DVD shrink and Nero?
    i think im just going to get Nero and try it with DVD shrink
    Sonic=sucks
    -Cody
  • masanz1
    masanz1 Posts: 511
    I had a problem with the newest version of nero and dvdshrink 3.2. I went back to Nero 6.0.0.9 and had no problem. As was said earlier, I find it best to keep the compression above 70 percent. DVDshrink decrypts then burns. Had no issue with any dvd using the 2
    Matthew
    Sometimes the road less traveled is less traveled for a reason
    HT
    Yamaha RX-V2500
    CS400-Center
    SDA 1A-Mains
    RT20-Surround
    None right now-Rears
    SVS 20-39PCi
    Infocus IN72
  • Sami
    Sami Posts: 4,634
    You don't need to compress anything with DVD shrink. First click on re-author and drag the main movie to DVD structure. Then click on compression and if it still shows less than 100%, remove the unnecessary soundtracks and only leave 5.1 DTS or DD. If that still doesn't do the trick, click on the icon with two opposite arrows, that will allow you to specify which chapters to copy. This will allow you to divide the movie into two discs, f.e. chapters 1-10 into disc 1 and 11-20 to disc 2.
    BTW, burning with DVD Shrink is slow and also a memory hog. Put the movie into an image and burn the image with Nero.
