Would a CSiA6 center speaker sound right with vintage Polks for HT?
I recently upgraded my living room TV to a 75" and no longer have a place to put the single SDA CRS I have been using as a HT center speaker.
Would a CSiA6 center speaker be a reasonable match sonically for HT use with SDA SRS fronts, RTA-15TL rears and Monitor 5b surrounds?
If not, any suggestions on a good but similarly sized center speaker that would be compatible would be appreciated, thanks.
  • boston1450
    boston1450 Posts: 7,758
    edited November 2015
    I have no idea about that one-honestly. Have you thought about a cs400i. I used one on 1c's & it was very good. They can be had minty for around 75-100.00 +shipping usually ive seen & bought even on the bay
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Nightfall
    Nightfall Posts: 10,083
    Would a Monitor 4, 4.6, or 5jr be too big?
    CS400/CS400i is usually quoted as being a pretty close match. @nbrowser uses a CSiA as a center and I think I remember him saying it wasn't a good match with his SDA's.
    Monitor 5jr
    afterburnt wrote: »
    Village Idiot of Club Polk
  • That's 2 votes for a CS400(i), will look into that. The new speaker will have to go under the TV on the front of the stand, I can raise the TV on blocks or something 7" or so to fit something like the CSiA6 under it but would prefer not to go much higher.
  • Nightfall
    Tacitus86 wrote: »
    You could set the TV ontop of a full size Monitor 5. That's what I did, but I used them both instead of one.
    afterburnt wrote: »
  • boston1450
    ^^^^ i always enjoy see'n that picture. Sweet
    Randy-Maine
    by David WMG
  • I would also vote for the CS400i. I have used mine with SDA-2A's and now with Monitor 7 series II with nice results.
  • westmassguy
    westmassguy Posts: 6,850
    The CS350LS would be my choice. It was Polk's TOTL back in the day.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Dabutcher
    Dabutcher Posts: 2,606
    I use a CSiA6 as my center. Sounds great to me? I have five Jr.s and monitor 7a pair to use .sounds like a Kool idea? How do you hook up two centers to same amp connector? Good luck. D
  • Nightfall
    Depends on the impedance of the speakers you're talking about and the quality of your amplification.
    afterburnt wrote: »
  • boston1450
    Dabutcher wrote: »
    ya run them parallel
    Randy-Maine
    by David WMG
  • xjghost
    xjghost Posts: 1,115
    boston1450 wrote: »
    Dabutcher wrote: »
    Out from amp in to speaker then out from that speaker in to other speaker?
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • westmassguy
    An AVR might have problems in Parallel. Try Series 1st
  • Dabutcher
    Had a emotiva xpa-3 driving center and rears 200x 3. Now have my new to me B&K AVR5000 running rears and sides and center If I remember right 125x5. I would love to try my pair of Monitor 7a's I am not using . Thanks. D
  • boston1450
    thats what i ment. You advised me of that a couple years ago when i used the 5's on my Yamaha rxv1 worked great too
    Randy-Maine
    by David WMG
  • I have used the CSIA6 center with SDA2A's, SDA2B's, and SRS2's. The CSiA6 works great with all the vintage speakers I've tried it with. It is really an excellent center speaker.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    There used to be an article on the preceding Polk website (FAQ's) that listed which center and surrounds were best matched with vintage Polk loudspeakers. IIRC it was in fact the CSiA6 that was recommended to be used with SDA's and Vintage Monitors.
    Found it...
  • There used to be an article on the preceding Polk website (FAQ's) that listed which center and surrounds were best matched with vintage Polk loudspeakers. IIRC it was in fact the CSiA6 that was recommended to be used with SDA's and Vintage Monitors.
    Found it...
    Thanks for this info Jeremy!
    Everyone's comments have been helpful, will start with a demo of the CSiA6 since it's the only one suggested that's still in stores to see how it sounds.
  • indyhawg
    indyhawg Posts: 1,675
    I use the CSi A6 with my 3.1TL's with good results. Has anyone ever A-B'd the CSI A6 and the CS400(i)?
  • PolkieMan
    PolkieMan Posts: 2,446
  • That is a fine looking rig, looks like it could bring down the house If you weren't careful.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • PolkieMan
    Thanks, I had a Cs2 Series2 it didn't sound right. Subs are only used for movies (receiver's crossover 120hz) that way I take all the low end noise and explosions off my babies.
  • PolkieMan wrote: »
    I like your idea of having the subs doing all the heavy lifting for special effects. Not sure though If I understand how you accomplished that, I might give that a shot with my rig. Thanks for the idea
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • boston1450
    PolkieMan wrote: »
    A few years back i used the Cs2 with some R30's on F & 15's on R & the Cs2 sounded pretty darn good
    Randy-Maine
    by David WMG
  • I took another look at my settings based on what Polkieman did and found that all my speakers were set to the large setting. I reset them to the small setting and re adjusted my sub I understand this is the right thing to do per other posts I read here on the forum. My understanding is by running my mains and center on the small setting the receiver will divert more of the Bass to the sub and make life a little easier for the amp, any thought on this?
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • PolkieMan
    Yea cause your right the deep bass is what eats up your power besides let the sub handle all the the rattling.
  • To wrap up this thread I was able to demo the CSiA6 and liked the way it sounded, so I bought one in the cherry finish and it seems to fit in well with my overall system for home theater use.
    The tonal match is good with the older speakers, and driven with 200 watts it produces clear and accurate (at least to me) center channel sound at any reasonable volume. Now if the movie sound editors could do something about the mismatched volume levels during the action sequences...
    Thanks again for everyone's input on this topic.
  • boston1450
    Congrats. Im sure shes purdy & it sounds like your feeding it well too. Enjoy your new center speaker
    Randy-Maine
    by David WMG
  • Nightfall
    edited December 2015
    Tacitus86 wrote: »
    That's called dynamics. Something music has been lacking lately. I don't know about yours but my Yamaha AVR has a setting that limits that sort of thing if you'd rather an explosion be the same volume as a conversation. I only use it at night, along with the bass turned all the way down to -6 and the dialog lift on maximum - to be kind to my fellow apartment dwellers.
    afterburnt wrote: »
  • Nightfall wrote: »
    Tacitus86 wrote: »
    I'm using an older Yamaha RX-V3000 that I bought new which allows you to set the front L&R main speakers to a maximum of -10db for surround programs, these are where most of the increased volume comes from. There's no capability to raise the center levels.
    I set the center and main speakers as 'small' to offload the very low frequencies from these 3 to the subwoofer.
    The sub itself is set to 0 gain, and the output level is set to about 2 (out of 10).
    This is everything possible with the current setup, but when an action sequence kicks in the volume on the front L&R speakers is still much higher than the center channel that I would prefer.
    The newer AVR/preamp/processors seem to have more capability in terms of customizing individual channels and Christmas is coming, maybe Santa will bring something.
