help please
  • subman32
    subman32 Posts: 27
    edited June 2004
    battery idea is a good one..... i use it all the time for proper wiring. but dont do 9v or else you could possibly blow one. keep it around a AA or a AAA. learned from the 9v by experience
    Garry
  • btnhfan
    btnhfan Posts: 20
    edited June 2004
    i love polk. they said because it is unde warrenty they will replace them. all i have to do now is find my sounddomain receipt.
  • exalted512
    exalted512 Posts: 10,734
    edited June 2004
    i, for one, am extremely fond of Polk's return dept.
    -Cody
  • Systems
    Systems Posts: 14,872
    edited June 2004
    why would you use a AA or AAA? their volatage is like 1.5 or so....you would want something closer to 12 volts
    Testing
    Testing
    Testing
  • subman32
    subman32 Posts: 27
    edited June 2004
    i'm talking about testing the sub for proper wiring or if it is recieving power. all you need is that little movement or pop. AA and AAA are just enough for that.
    Garry
  • Buff013085
    Buff013085 Posts: 24
    edited September 2004
    same thing happened to me except i only have 1 mm10. i am only giving it 300 watts and i have had to send it in to get repairs 2 times. this time i am selling the sub. i have never had this much problem in less than 7 months from a sub ever.
    looking for a good amp and maybe some subs!
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    You are all WRONG! WRONG,WRONG, WRONG!!!!
    Nah, I'm just kidding...
    My question is: what does your meter read for resistance (ohms) for the sub when you have the leads connected to the sub wires, and the wires only connected to the subs?
    Here is a guide to troubleshooting subs:
    GIVEN (stuff to keep in mind):
    >>Digital meters sit and give random readings with nothing connected (inf. ohms) and Analog meters read at infinity.
    >>Digital meters will read 0.04-0.6 ohms to be in-precise when connected, this tends to be the impedance of cheap test leads. and Analog Meters tend to be adjusted to the leads attatched and will read 0 ohms
    IF the readings are:
    (1)>>0 ohms when connected to the sub wires.
    (2)>>infinity ohms when connected to the sub wires.
    (3)>>High reading (ie. 500-10K ohms)
    (4)>>1,2,4,8 (+/_ 0.3) ohms when connected to the sub wires.
    (5)>>0 - Infinity depending on how the box sits, or moves.
    THEN:
    (1)>>Yes, you have a short, if it does not void a warranty, test the sub directly to the driver. If same, the sub is shorted, if different, your wires are crossing somewhere.
    (2)>>You have an open, test driver directly, if different, the wires are to blame again.
    (3)>> Check at driver, if the same, your coil is definitely fried. In this case, you will normally still get low sound from the driver, unless the coil is stuck.
    (4)>>Seems like the coil wire is good, The coil may be stuck, try pushing the sub in a little to un-stick it.
    (5)>>Definitely a wire poblem, check the wires in the box, also the tinsel leads from the cone/spider to the driver's terminals.
    Remember, your wiring may have a short in it from melting together inside or from a cut or cross, especially if there short-circuit run through the wire at any time.
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
