Rocketfish Wireless Rear Surround Kit
[Deleted User]
in Speakers
Hello Everyone,
I have been messing around with the Rocketfish Wireless Rear Surround Kit. The latency seems fine but I'm having an issue with low volume. Just as a test, I'm using RTiA A1s with the setup. Has anyone else used this or another wireless kit with good results?
http://www.bestbuy.com/site/rocketfish-universal-wireless-rear-speaker-kit-black/8275528.p?id=1171058476489
Don't expect them to give you the performance of connecting them directly to your AVR or amp... They are transmitting the signal not the amplification and you can't expect the amp in the receiver is of any quality or performance .. I don't see specs on the amp, but that is where it is lacking.
I don't know if you can connect the "receiver" to an external amp located back by the rears but that would be a solution.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Looking at some of the reviews...I found the sound output to be somewhat lownot enough power comes out of the tiny little rear end reciever for it to power them.The amp is only useful for a small satellite speaker. Didn't work that we'll with a medium sized bookshelf speaker.
I can't imagine a 2 pound amplifier running off a wall wart to have sufficient power for any decent bookshelf speaker, even if it is a class D amp. Also seems like reliability of the product is very poor.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
This was in our Best Buy Store and wasn't that impressed with it. They were running the Klipsch Surrounds and had the amp maxed out and barely got any output from it. Also from what I remember it got replaced a few times because it died after about a month or two of use (now granted the thing is on 24/7 there but still). I would have to say to stay away from it.
Years ago when my brother-in-law lived in an apartment & had no way to run wires, we used a Kenwood RFU-6100 to power the rear surrounds. I remember it doing an adequate job. They are no longer made, but maybe you can find one on the used market.
When I took the tiny amp out of the box, I knew I was in for underwhelming performance. Of all the wireless kits on the market, very few (available new) provide more than 25 watts per channel.
To me if there was a wireless device that would allow me to pre out to real amplifiers in the config would be useful. 25 watts is probably not very usefuelMy New Year's resolution is 3840 × 2160
Mikey081057 wrote: »To me if there was a wireless device that would allow me to pre out to real amplifiers in the config would be useful. 25 watts is probably not very usefuel
Agree with this. Honestly give me something I can plug into a good amp and not something that is a crappy 25-watt amp that can't drive anything.
Take a look at the outlaw audio oaw3. I think aperion audio makes a similar device.
@nbrowser A wireless kit with just the banana plugs that would allow me to connect to an external amp would be ideal. I'll do some searching and ask our guys in Baltimore to see if they have any ideas.
I have a slightly different Rocketfish setup. I picked it up a couple of years ago.
It consists of a wireless transmitter and a receiver. The receiver has the ability to accept RCA, mini and wireless. Its about Half the size of a regular component and also has 25 wpc. It has volume control, input selector, power button and wireless remote control.
I have it on the patio connected to in-ceiling speakers and connected to a system in my bedroom via wireless. For what it is it is a really good product. I think I paid about $75 for both the transmitter and receiver.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources. -
Look at this recommendation.
https://www.outlawaudio.com/products/OAW3.html
Contact Outlaw to ensure it will work for your situation, but I believe it has A/D and D/A converters so it should work. While the sound is not optimal from this piece, its not a bad option, especially considering the application.
He would still need amps2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
The world is his oyster there. All he needs is analog inputs. Volume is still controlled by the feed into the transmitter.
But if he's trying an installation set up where he can't get the cable to his head end (which is what I perceive) then the remote amp more than likely will be the budget killer.
He could look for a pair of single channel small form factor class D amps that would provide the wireless integration for the Outlaw transmitters.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
This rig also looks promising.
http://www.bhphotovideo.com/c/product/1112666-REG/denon_dn202wt_dn_202wt_wireless_audio_transmitter.htmlMy New Year's resolution is 3840 × 2160
The whole point of the rocket fish is to power the speakers and send signal without wire
So you need amplification and transmitter at the speaker
txcoastal1 wrote: »The whole point of the rocket fish is to power the speakers and send signal without wire
Yes, but looking for un amplified receivers where you can apply some real amplification for the rear channels.
My question would be ... would it be better to have crummy wire or wireless and good wires? I already have crummy flatwire under carpet. Looking for alternatives too.
The Rocketfish is still going to require speaker wire from the transmitter to the speakers. The Outlaw unit plus the Parasound Zampv3 for sale in the flea market would give him a much better solution than the Rocketfish & a small form factor also.
Heck, I've been eyeing up that Parasound. I don't need it, but those are great small form factor amps.
Mikey081057 wrote: »txcoastal1 wrote: »The whole point of the rocket fish is to power the speakers and send signal without wire
I have only used transmitter for a sub woofer signal never tried on surrounds.
Been awhile since I've done residential. Dan may have an answer or I could call the my distributor to see what's been used and update recently.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I've been researching option where I can run my rear surrounds wirelessly and came across these:
http://www.jlaudio.com/jlink-trx-home-audio-wireless-kit-96102
Has anybody used anything from JL?
Mikey081057 wrote: »I've been researching option where I can run my rear surrounds wirelessly and came across these:
Interested to hear as well. Planning on going 7.1 but have putting it off as running wires that far to the back will be a PITA. -
I guess the 2 things that would concern me most are:
1. Delay
2. Interference from other devices
3. Frequency response.
OK that's 3 things.
The FR on these is 16th to 22Khz. Which should be no issue. Other cheaper ones were chopped to 30 to 12Khz. That might work OK but might chop the higher freqs that the lsim ' s can reproduce no?My New Year's resolution is 3840 × 2160
In the end tho it might be a wash to have the electrician just pull the wiresMy New Year's resolution is 3840 × 2160
