No bass from monitor 10
bcbud3
I have been having trouble with one of my monitor 10s. I just replaced one of the mid drivers, i press on the passive and the mids move outward, couple of seconds to return to normal resting place. I turn it on and i get no bass. When i listen to the good speaker i can hear decent amount of bass coming from the mids but on my other one there is almost none. The passive puts out zero bass right now. Is this a crossover issue? If so, what value resistor/cap would i need to replace?
Hello,
The first thing that comes to mind is that one of the 6.5" drivers is wired in opposite polarity to the other. Try removing the driver you just replaced and swapping the positive and negate wires around.
Regards, Ken -
^^^ out of phase sounds likeSpeakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5 -
i hope not, red dot on speaker would be white wire correct?
No, the black wire is the positive. That's the problem.
Wires swapped and i am back in business! thank you!
