Good place near Philly for speaker repair?
Jstas
Got a friend with a pair of Advents that need a refoam. He's looking for a place that could do it if possible.
Anybody know one in PA near Philly?
Expert Moron Extraordinaire
Millersound comes to mind. Though Advents are ridiculously easy to re-foam. Unless he's all thumbs tell him to give it a try.
Depends on which Advents he has. The 80s to present are pretty straightforward, but the early, "Large" Advents, with the Masonite ring can be a PITA to work on. The later "Large" used a more conventional stamped steel frame without the ring. Both were designed and hand built by, or under the direction of Henry Kloss.Millersound comes to mind. Though Advents are ridiculously easy to re-foam. Unless he's all thumbs tell him to give it a try.
They were also used in the Dahlquist DQ-10Home Theater/2 Channel:
dhsspeakerservice.com/ -
I have a guy in Collingswood I have used for years John. Fast turnaround, good work. Pair of 10"ers should be less than $70. Maybe less than $60.
That would be him John.
