2BTL Issue
I performed the tl mod on a pair of 2Bs about two years ago. A subsequent static/buzzing noise seemed to have been solved with a repaired solder joint. Now, after two years, I am noticing that static/buzzing noise when deep, loud bass is played on the LH inner mid driver. I have switched drivers and speaker cables to confirm the issue is not with the driver or the amp and must be with the crossover. All solder joints have checked good. Could one of the Sonicaps be defective? Any ideas on tracing down this problem? Thanks for the help.
