Speaker Cabinet Face Repair
stogie
Picked up a pair of RT5's for a few bucks but one of the cabinets looks like a dog chewed on the bottom front. What is the best way to repair this damage- some Bondo and spray paint? What is the stuff Polk used for the cabinet faces? Can it be easily sourced and used for repairs?
Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
TT: Technics SL-MA1
Doesn't look horrible in the pic. Can you hit it with a sharpie?
it's actually gouged out- could use some filler to even it out with the rest of the surfaceSpeakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
TT: Technics SL-MA1
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5 -
It appears to be a vinyl coating. Guys that repair car interiors should be able to fix that, but it'll cost more than the speakers are worth.Political Correctness'.........defined
President of Club Polk -
that's what I was afraid off. i'll just try some type of filler and paint or sharpie and see how it turns outSpeakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
TT: Technics SL-MA1
Ok, you can try using Bondo or wood epoxy for the filler. Do not use wood filler. You'd be better off cleaning up the jagged tears. Use a razor blade or the like to cut away the jagged stuff leaving nice straight cut lines. Fill the area and sand flush. There are various textured spray paints available, which should help hide the repair. Keep in mind that there are a thousand shades of black, so an exact color match will be difficult.Political Correctness'.........defined
Forgot to mention, when using the filler and sanding be sure to tape off the surrounding area as to do as little damage to the vinyl as possiblePolitical Correctness'.........defined
ok, thanks for the advice. I might try some brand of black of wood filler stick like this:
http://www.amazon.com/Guardsman-500300-Filler-Sticks-Shelf-Tray/dp/B0057IV5PYSpeakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
TT: Technics SL-MA1
Those are colored wax sticks, not really what you need.Political Correctness'.........defined
This worked pretty good on the vinyl armrest of an old car. I got it at Walmart. I'm sure auto parts have it too.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
