Quick SDA mod question
sfosselman
There is a round plastic disc covering up a hole behind the PR on my 1C's. Should that be sealed?....right now it is stuck on but not permanent
Polk SDA 1C Upgraded, Eastern Electric Minimax Supreme DAC, Parasound HCA 1200ii, Belles 21a Preamp, Rotel RSX-1056, Matricom G Box Q, Blue Jean & Signal Cable interconnects, Sonographe SG-3 TT, Panamax M4300-PM
Are you referring to a hole in the back wall, with a plastic plug in it? If so, those were installed where the old IC connector was, when Polk was using up leftover 2A cabinets.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Yes....should I seal that with loctite since it will not be used?Polk SDA 1C Upgraded, Eastern Electric Minimax Supreme DAC, Parasound HCA 1200ii, Belles 21a Preamp, Rotel RSX-1056, Matricom G Box Q, Blue Jean & Signal Cable interconnects, Sonographe SG-3 TT, Panamax M4300-PM
Also its not really a plug as much as a disc stuck onto the back of the cabinetPolk SDA 1C Upgraded, Eastern Electric Minimax Supreme DAC, Parasound HCA 1200ii, Belles 21a Preamp, Rotel RSX-1056, Matricom G Box Q, Blue Jean & Signal Cable interconnects, Sonographe SG-3 TT, Panamax M4300-PM
Yes, you should seal it with the LoctiteHome Theater/2 Channel:
Ok...thanksPolk SDA 1C Upgraded, Eastern Electric Minimax Supreme DAC, Parasound HCA 1200ii, Belles 21a Preamp, Rotel RSX-1056, Matricom G Box Q, Blue Jean & Signal Cable interconnects, Sonographe SG-3 TT, Panamax M4300-PM
