Monitor 7 Speaker Post Replacement
One of the posts to my Monitor 7's is broken (see picture).
I removed the cross over and it looks sealed on the backside.
Any thoughts as to how to replace this?
Thinking I'll order all new posts, but just not sure how to get the old ones out.9bnmskrbhmqs.jpg
2 Channel "Polk" Room:
Marantz PM8004 Integrated
Marantz SA8004 SACD Player
WiiM Mini
Polk 7B with RDO198s
  • The posts are covered in hot glue. Just pick it off. You can use a small screw drive. Once clean, take them apart and replace. After reassembly use hot glue again to prevent air leaks.
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
  • Jaybeez
    Jaybeez Posts: 748
    Great thanks, very helpful.
    Assuming after cleaning "take apart" means removing the ring at the base of the shaft, adjacent to the backside of the crossover?
    WiiM Mini
    pitdogg2 Posts: 27,430
    I may have an old one you should be able to still use your cap can't remember off hand if mine are just like that or octagon either way it would be an unscrew re-screw type of switch in all likelihood
  • Jaybeez
    Jaybeez Posts: 748
    If you have any laying around that might be best. Seems they are an off size and not carried by any of the vendors I've been able to find. Called Polk and they don't have the part, and couldn't verify the size, though the bolt sizing guide at Lowes indicates it's 8-32 (.1640). If yours is different no worries, I'll keep looking. Thanks!
    WiiM Mini
    mine are factory like yours. drop in replacement I will make sure to check tonight.
    pm me your name and address
    So hello I have two sets just like those.....drop in replacement just add hot melt glue to finish.
  • Jaybeez
    Jaybeez Posts: 748
    If you don't need them, would love to take them off your hands. The 8-32 Home Depot bolt/washer/nut combo is getting the job done, but would like to do it right and put the last banana plug in place!
    I PM'd my contact information.
    MUCH appreciated!
    WiiM Mini
    I have no PM's from you...
  • Jaybeez
    Jaybeez Posts: 748
    Totally confused. On 10+forums and struggling to figure out the mechanics of this one ...
    WiiM Mini
    F1nut Posts: 52,050
    Jaybeez wrote: »
    Welcome to the format disaster known as Vanilla.
