RTA-8T compared to RTA-8TL
lancemartin414
I have a pair of vintage towers. One has the RTA-8T model number on the back and the other has RTA-8TL. They look the same. Can anyone tell me the difference between them.
There are several possibilities. Most likely Polk was using up leftover labels, which is quite common. The 8ts would have SL2000 Tweeters. The 8tls would have SL2500 Tweeters. The 8ts had MW6510 Woofers, and the 8tls had MW6516 woofers. The Crossovers would also be different.Home Theater/2 Channel:
dhsspeakerservice.com/
