AVR for Polk RTI A7's
Hello all,
just bought two Polk RTI A'7s to start building my audio system, and I was wondering if the Pioneer Elite VSX-80 7.2-Channel Network A/V Receiver is a sufficient AVR to power them. I'm a bit strapped for cash so I'm looking for value. Thanks for any help.
    F1nut Posts: 51,685
    Are you building a 2 channel music system or an HT system?
    tonyb Posts: 33,066
    Yes that receiver will drive them, not to their best ability though. For HT use, that receiver should suffice but for music listening better options are out there.
  • mantis
    mantis Posts: 17,319
    No man I'm not feeling that receiver for the RTIA7's. Yes it will make sound but I feel if your strapped for cash go used and get a SC model. They have way more power and will power the RTIA7's wonderfully.
    I'd look at the SC-65. You will get a better deal on that then a new VSX-80.
    Dan
    tonyb Posts: 33,066
    edited October 2015
