What connector pins did polk use on their SDA harnesses?
Help... does anyone know which female pins polk used for the mate n lock connectors. I am replacing all the driver harnesses in my SDAs and purchased the wrong ones from mouser. I am confused as to which ones I need I am using 16awg wire. Thank You..
Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub
    F1nut Posts: 51,964
    Pins - Mouser #571-3505471
    Sockets - Mouser #571-3505501
    Rated 14-20 AWG
  • F1nut wrote: »
    Rated 14-20 AWG
    Thank You Sir
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
