VPI 16.5 RCM Record Cleaning Machine
ecod123
It is the newer version, has the rocker switches instead of the metal toggle switches. Works well. Very good condition. See pictures. Upgraded, hence this sale.
Extra new suction wand included. Owner manual, power cord, brush and original factory box and packaging.
$450 plus shipping. Paypal (add 3%) or USPS MO.
Pics will follow.
Pics will follow.
This is a good deal for anyone looking to get into a high quality RCM! This is your huckleberry! GLWTS!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
PM Sent2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
Post edited by ecod123 on -
Thanks, MrBuhl! -
I'm next on this...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
You got new PM.nooshinjohn wrote: »I'm next on this...
Did not get the PM, but I will let you know in the amThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Bump for a nice guy and a great rcm... Need to hold off because we need to redo the front of the house and a master bath.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »Bump for a nice guy and a great rcm... Need to hold off because we need to redo the front of the house and a master bath.
Thanks for letting me know. I understand. All the best on the remodel. -
Is this still available?
I know it's sold but I'd like to know more about these things. How do these work? Is there a solution plus vacuum? Does it really clean an old record well?HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
Hi @xjghost - solution plus vacuum yes with what I would describe as a very light brushing action from a velvet like brush as it turns.
And yes, it doesn't fix scratches, but in terms of taking your vinyl replay to the next level, nothing cleans like a vacuum record machine IMO. Old dusty pops and clicks are virtually eliminated in my experience.
There are newer more expensive (and much slower from my research) cavitation based machines, but they're out of my price range.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Thanks!
xjghost, +1 to what MrBuhl said. Helps with new LPs too, for example, removing mold releasing chemical residue and manufacturing artifacts.
Will probably prolong your stylus life too.
Here's an instructive YouTube review on the 16.5 rcm. https://m.youtube.com/watch?v=pZB0oUJu-00
