Break in for LSi7
okiepolkie
okiepolkie Posts: 2,258
I have just received a new set of Polk LSi7s. I know they need to be broken in, but I am not sure how to do this correctly. Any help would be appreciated.
I am running them with a Yamaha rx-v2092.
Thanks.
Tschüss
Zach
    F1nut Posts: 51,752
    edited September 2004
    Hook them up and play a constant source though them for at least 100 hours, then sit down to listen.
  • gmorris
    gmorris Posts: 1,179
    Just play them, forget about breaking them in. By simply using them as they are supposed to be used, they will break in all by themselves. There is no procedure or plan, per se.
    Enjoy...:)
    Bob Mayo, on the keyboards. Bob Mayo.
