Covering banana plugs
Easy Runnin
I have some outdoor speakers I bring in for the winter. I want to protect the banana plugs from moisture. Any suggestions?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
You could go to an autoparts store and find the correct size vacuum plugs to fit the bananas.
http://www.oreillyauto.com/site/c/search/Vacuum+Caps/N1167/N1171.oap
Personally, if they are plated I'd probably just leave them bare, rather than possibly trap moisture in the connector and wire. -
I agree with William on this one. If they are gold plated no biggie. the only other thing I can offer is shrink tubing, A buddy of mine does it every winter then cuts it off in the spring.
My speaks stay out all year long w/plated bananas--never had a problem.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
A salt air environment is harsher than most others. I think I’ll get the vacuum plugs, pack them with grease or Vaseline and then insert the banana plugs.
ThanksHT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
BR - Yamaha CR800/Polk monitor 5 -
what about just bagging the ends?
grease/vaseline sounds like a troublesome mess in the Spring.I disabled signatures. -
Always a good idea to use vaseline when packing the banana in a harsh enviroment.
Is this code for something else....lol.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Idolizing a politician is like believing the stripper REALLY likes you. -
My outdoor speakers stay out side all year around. They have been out there for 12 years and still work just fine.
I use silicon when I install wire into the binding posts. I put a small coat on them to keep moisture out and it works for years and years with trouble free listening.
If your going to take them in and cover the wire, the Dielectic grease following by plastic wrap is a wonderful Idea. Thats what I would do if I was going to bring my speakers in each winter.Dan
