2 Channel Refinements
  • Mikey081057
    Mikey081057 Posts: 7,127
    WagnerRC wrote: »
    I am very happy with my music hall table. Very nice system Mikey
    I don't use mine as much as I should, but it is very nice table for sure.
    Garage | Polk Monitor 5B's
    msg Posts: 10,460
    beautiful setup, man.
    I have a few questions, if you don't mind.
    which subs are those? MicroPro somethings?
    how do you find the spacing off the wall with the 2.3's? any oddities?
    what are your platforms? did you make them? they look cool.
  • Mikey081057
    Micropro 3000's.
    Room is not optimum for the 2.3's but still get a nice soundstage. I wish the room was bigger but ...
    All of the platforms are by auralex... Subdudes under the subs and Grammas under the 2.3's. They work great calming down the subs and decoupling the 2.3's.
  • Mikey081057
    The P5 does a great job of handling the subs at high and low volumes. So far very comfortable to listen too. The synergy between the P5 and the A21 is something to be heard.
  • ukcolin99
    ukcolin99 Posts: 286
    Very nice, love the balanced look, more components the better, 'bigger the speakers....
    msg Posts: 10,460
    Thanks Mike. yeah, was just wondering whether you noticed anything on the 2.3's since they make recommendations for placement. I don't have the perfect space for mine, either, but whatdya do.
    Thanks for the info on the platforms. Interesting.
    Micropro 3000's.
