i need to choose a power amp
Kinetic
Kinetic Posts: 437
edited October 2015 in Electronics
guys I recently change my beloved Polk LSIM for a pair of PSB Synchrony ONE
Im moving them with a Marantz PM8005 (70watts) Integrated AMP fairly nice
but since my PSB are power hungry, and my Integrated AMP can become a Pre-Amp...
I can add some Juice for a fair Price.. (800 dls for 140watts)
My first and obvious pick would be the Marantz MM7025, since I already have the Marantz Pre-Amp, the Marantz Network Player, and the Marantz Disc Player (and a Marantz/Clear Audio Turntable will be coming soon)
The Marantz MM7025 is $800 DLS wich I consider cheap and gives me 140 watts at 8ohms wich is double of the power I have (and this is awesome for me, really) but at that Price range.. Am I lowering the quality of my system???
The other choice was to change my existing Integrated Amp for the Marantz PM11S3 wich is even more powerful, (I ignore if its better in SQ. however "Marantz US" claims that is the same SQ as the one I have) but that is an staggering $5,000 Dls
five thousand dolars??? no way...
I dont really understand how a pre amp Works in terms of quality, when you hook up a power amp, does it matter? or it just become a volume knob??
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
    Yes pre amps matter as well to the SQ.....everything does. Cost wise, I'd look at used amps. McCormack, Parasound, B&k, Belles, just to name a few and most can be had under 800 bucks and provide enough juice and then some for those PSB's.
  • Kinetic
    Kinetic Posts: 437
    DSkip wrote: »
    I'd look elsewhere. What is the rest of your rig - model numbers please. Cables?
    Marantz PM8005 Integrated Amp
    Marantz UD7007 Disc Player
    Marantz NA6005 Network Player
    PSB Synchrony One Towers
    Richard Grey "The Power Co" Power Plant
    Cables:
    Knu Konceptz EKS RCA Cables
    Knu Konceptz Karma SS Speaker Cables ( the "krux" cables are coming..)
    Knu Konceptz Gold Plated bananas
    Furukawa PCOCC power cable
    Z
    Polk Audio SR 6500
    G35
  • Kinetic
    Kinetic Posts: 437
    tonyb wrote: »
    Parasound is officially selled in mexico, the are going to give me the 150 watts to check it out, however I dont like it too much. The sound is a bit harsh, and the PSB Synchrony One needs a warmer sound, similar to a tube amp, or like a Marantz...
    im going to check out the McCormack and the belles..
    Z
    Polk Audio SR 6500
    G35
  • Mikey081057
    Mikey081057 Posts: 7,127
    The Parasound A23 plays around that price point and is very solid.
    Garage | Polk Monitor 5B's
  • Mikey081057
    or maybe a tube amp is the answer
  • Kinetic
    Kinetic Posts: 437
    thats the one Im going to play with..
    Z
    Polk Audio SR 6500
    G35
  • Kinetic
    Kinetic Posts: 437
    DSkip wrote: »
    What is the exact issue you are having with the sound?
    Polks LSiM703 where having a nice prescence at almost any volumen, and does could play loudly
    PSBs are big towers, I dont feel the prescence or the scenario that they could do, they almost do it at high volume levels...
    most people say that this is becouse the PSB towers are power hungry, and a bigger amp would help a lot, Im not looking in improving the detail or tonality, i just want to have a nice scenario and prescence at regular volumes..
    im not sure if i explain my self good, however i think you guys got the overall idea..
    Z
    Polk Audio SR 6500
    G35
    Kinetic wrote: »
    DSkip wrote: »
    What your describing is the lack of power and how it relates to the sound your hearing. This is where an amp helps, better dynamics at lower volumes, more clarity. Find a good used one, a good set of interconnect cables to hook it up and you should be pleased.
  • erniejade
    erniejade Posts: 6,321
    A bigger tower like the sync one does need some power to open them up but, they also need to be played a little bit louder vs the polks to get them to open up. The polks can sound more alive at lower volume. This is almost true of a lot of well built bookshelf speakers vs floor standing towers. I have heard the psb imagine t2 and t3. They sounded wonderful on NAD gear at the store and my mcintosh mc402 when I had them on trial at home.
    I have not heard the sync one but I have read a lot lf the technology used in the t2 &t3 was used from the sync one.
    My question is if you liked how vibrant or how the polks surrounded you, why didnt you just add a decent subwoofer to them to get more kick out of them?
    So besides being slightly underpowered, how do you like the psb?
  • Kinetic
    Kinetic Posts: 437
    1.-the polks have a big impact in mid bass, bigger than the PSBs
    the PSB are better in all the other things.. by far.. and I get them with 60% off of my local store, since they are not selling PSB anymore..
    2.- The PSBs are one of the most natural sounding speakers that I ever heard, how ever it takes you some time in your house to really love them, those speakers are like a really good song, it gets better with the time..
    the only ones better where the KEF Reference, but those where more expensive and without a discount, there was no way I could pay them (and also better not by much)
    Z
    Polk Audio SR 6500
    G35
  • erniejade
    I understand what you are saying. A bigger amp will help but, it won't give you the mid bass slam the polks have. Again, I have not heard the sync one but the t2 and the new t3 are natural sounding speaker with sweet highs so I get what your saying. The psb t3 is the new top pf the line for them so a discount will be a long time before you see one.
    Btw congrats on the sync one. If yours are brand new, give them a good 300 hours of playing. They will open up even more.
  • BlueFox
    BlueFox Posts: 15,250
    For my PSB Synchrony One towers I started with a single stereo Cambridge-Audio 840W in stereo mode. Later I bought another, put both into bridged mono mode for 800W/ch, and was in heaven. The PSBs loved these amps, and they are one of the best buys in high-end audio. I also had the 840E pre-amp.
    Here is the latest version of this wonderful amp.
    http://www.audioadvisor.com/prodinfo.asp?number=CA851W
    I still use both of them in my multi-channel system where they power Aerial Acoustic 7T speakers in the front.
    These amps easily held their own with the Pass amps, but when the volume gets up there then the Pass takes over.
  • Kinetic
    Kinetic Posts: 437
    BlueFox wrote: »
    nice ones, now I know that power is the answer for the PSB Synchrony One
    Z
    Polk Audio SR 6500
    G35
  • Kinetic
    Kinetic Posts: 437
    erniejade wrote: »
    well I dont need the Polks mid bass, more is not always better..
    the new T3 are almost the same performance as the Synchoony Ones..
    and thanks a lot, my house is always open for audio enthusiasts, I will try to post a video soon
    Z
    Polk Audio SR 6500
    G35
  • MrRoboT
    MrRoboT Posts: 39
    What was the name of those older Cambridge stereo amps that could switch from stereo to mono? They went on sale at audioadvisor about 5 years ago and always wanted a listen.
  • lots of good advice here. If you like the A23 I'd hold out for the A21. I am.
  • Kinetic
    Kinetic Posts: 437
    are you selling the Parasound Halo A23?
    Z
    Polk Audio SR 6500
    G35
