how to get my rti a9 bottom rubber pad fixed
Saurabh
Hello,
I have just registered my RTIA9 with serial #997502963 and need help to replace a broken bottom rubber pad.
Case Details: Case Number - 00057613 Case Open Date - 9/22/2015 Case Status - Open
Please reply
Saurabh Saxena
9886503341
Bangalore
Please reply
Saurabh Saxena
9886503341
Bangalore
Best Answer
I believe Polk's CS manager has sent you a message asking for your address, correct?
Answers
Hello,
Welcome to Polk's forum. That part will have to be obtained through Polk's CS department at polkcs@polkaudio.com.
Regards, Ken -
That I know.
No one in CS dept is looking in to the case 00057613
looks like CS showing me being wrong. -
I'll forward this to Polk's CS attention.
Thank you so much Kenneth S
You might want to try using spikes instead of those rubber feet. You may experience some better bass response. If you have hardwood floors, they sell little discs for under those spikes.HT SYSTEM-
lsi 9's -
thanks for workaround ;
i do have hardwood floor with DFM acoustic insulation on floor for my studio and there the cosmetics matters a lot; since studio should not make DIY impression hence insisting on to get this rubber pad from
CS dept.
dont know when the day will come . -
that's correct Ken. Thanks a lot. You can make post as answered.
