DSW MicroPRO 4000
Well, I think I found the problem (see attached picture).
I pulled it apart and rigged it to be able to turn on with the sub connected while on the bench.
When I did, that little green guy shot sparks at me.
I'm 100% sure what it is but if someone knows for sure, I can replace that I think.
Expert Moron Extraordinaire
  • Jstas
    Jstas Posts: 14,994
    OK, nearest I can tell from positioning and what that looks like, it's a Metal Oxide Varistor for circuit protection.
    Anybody have an idea on what the specs are on it?
    Since this amp isn't working anyway, I figured I'd replace the two of them and see what happens. Nothing else on the boards looks damaged. I'll have to pull it off its mounts and see if any runs delaminated or burned but this might be an easy fix. Everything else looks good and this appears to just be the power supply board. Nothing else looks damaged and none of the power wires to the other boards are burned. I'm guessing it was an external surge that vaporized the varistor. Especially given its location on the board.
    I'll replace both since one blew, I wouldn't trust the other one.
  • Jstas
    Jstas Posts: 14,994
  • rooftop59
    rooftop59 Posts: 8,120
    I have nothing to offer, except that dude, I wish I had ur skills brother! Hope u get it figured out and working. Darkknight gave that sub a KILLER review years back. I've always wanted one...
    Game Room 5.1.4:
    Bedroom 2.1
  • ^^^ same here, but I'm enjoying mine. Not too bad of a sub!
    SRT Seismic System with dual PSW1200's
    RT5000 x 2
    RT2000p
    CS400i
    CS350-LS
    LS F/X
    PSW650
    PSW1000 w/Dayton SPA1000
    DSW MicroPro 4000
    Adcom amps
    Pioneer Elite SC-89
    Pioneer PLX-1000 Turntable
    PS4
    XBOX One
    MIT Interconnects
    BJC
  • I have had mine since late 2011. Like it, solid, glad I got it.
    Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
