Truck Tonneau Covers Extang vs Truxedo recommendations
gudnoyez
Is anyone familiar with tonneau covers for trucks I have the choice between the Truxedo Low Pro QT, or the Extang Tuff Tono, those are the only 2 the Nissan dealership sells and I get a discount from them so it's cheaper to buy from them than from an aftermarket dealer.
I know it's just a tonneau cover but it's the wife's first accessory upgrade on her new truck and I want to make the right decision. These are both rollups so we can utilize the full bed for hauling stuff does anyone have either of these two brands? If so what are your thoughts on them, not interested in solid covers or tri folds. Opinions appreicated. Need to keep her happy so I can keep the WAF factor in check.
http://www.truxedo.com/lopro/land.php
A couple of links
http://tonneaucoversworld.com/extang-tuff-tonno.aspx?gclid=CKKzv93qkMgCFZaHaQod_aIIUA
The thing I like about the Extang is that the bows are adjustable for a high and low profile option, the Truxedo is sexy looking.Home Theater
Hello, I've been using the same tonneau for 8 years three difference trucks. Great cover you should no problems if you go with this brand.
Cheers, Roger -
I had the truxedo on my f150. Good choice for warmer climates.
It rolls up quickly and neat. But Ice and snow tend to sit on it due to the
flat bars that roll up with the cover."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Cheers, Roger
Hey Roger which one the Truxedo or the Extang?sucks2beme wrote: »I had the truxedo on my f150. Good choice for warmer climates.
That's some of the feed back I'm hearing the Extang crossbars can be set for a low profile or a higher bowed application to help prevent the ice build up. Thanks for the input guys.
I prefer the BakFlip, I know not something you can get from the dealer but they are awesome...
http://h.bakflip.com/p-361-bak-revolver-x2-tonneau-cover.aspx
Our local lineX dealer sells the backflip brand, I'm particularly fond of of the Revolver your right this would be my sky's the limit Rollup Tonneau cover hands down this one is sweet.Home Theater
The truxedo,
cheers,Roger -
I prefer my Undercover model that I've had on my Ram 1500 for years. We have even sat on top of it in lawn chairs to watch fireworks without issue and its light enough for me to take off by myself.
tonneaucoversworld.com/Undercover-tonneau-covers.aspx?gclid=CJXcn46mkcgCFQgHaQod7t8BvgHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I had both the extang and truxedo on a 2005 nissan titan LE. I can say without a doubt that the solid tri-fold covers are WAY better than the fabric and much easier to take off and store. The fabric ones are just ok. The solid covers (like the bakflip) are very useful, practical and convenient. Just my .02 cents. I found mine on craigslist for around $200 as well.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
BakFlip F1 Tonneau Cover
Aluminum Underside - Reinforced FiberGlass Top
I preferred the Bakflip F1 vs Bakflip CS over the the all aluminum model
With the fiber glass top it won't dent2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
