Polk Audio DSW MicroPRO 1000 Power Cord?
Picked up a Polk Audio DSW MicroPRO 1000 but it's missing the power cord. Doesn't seem like a standard cord.
Anyone know where I could get a replacement?
Expert Moron Extraordinaire
  • Polk CS should have them at 1-800-377-7655 if you have trouble finding one.
  • Does it only have 2 prongs? If yes you can use a std 3 prong cord...The oe one is pretty cheap.
    Garage | Polk Monitor 5B's
  • Jstas
    Jstas Posts: 14,978
    Yeah, it's the two pronged one.
    I only have 3 pronged cables.
  • rooftop59
    rooftop59 Posts: 8,121
    U can use the 3 prong fine I think. The grounding pin just isn't connected.
    Game Room 5.1.4:
    Bedroom 2.1
  • Jstas
    Jstas Posts: 14,978
    Yeah, might have the shutoff problem though but for the price I paid, I'll figure it out.
  • Jstas
    Jstas Posts: 14,978
    Found a cable that'll work.
    Wouldn't turn on, though.
    Picked out the fuse. Blown.
    Can't find a new fuse easily. Ordered a dozen from the same place I got the cable.
    Should be here by the end of the week.
    Stay tuned, kids! We'll blow this thing up yet!
  • Jstas
    Jstas Posts: 14,978
    So it works when I replace the fuse for a little bit and then it pops the fuse.
    Any idea what would cause that?
  • That usually indicates a problem with the amplifier, best to contact Polk for service or replacement options.
  • Jstas
    Jstas Posts: 14,978
    I did, Ken. Was told to buy a $900 amplifier.
    But I did discover that this is not a MicroPRO 1000, it's a 4000.
    Also, I think I found the problem:
    http://forum.polkaudio.com/discussion/169583/dsw-micropro-4000?new=1
    Any ideas on what that green guy is?
