Tweeters for my RTA 11 T
Good morning all. This is my 1st post, here, as I am a new member. I am an old timer, owning a pair of LS 90s, as well as these RTA 11 Ts. I need to replace the SL 3000 tweeters, as they are blown. I need help. Thank you, Dan
  • 11tsteve
    11tsteve Posts: 1,166
    are they RTA 11TL's then, and not RTA 11T? The former had the SL-3000, the latter the SL-2000. Either way a drop in, updated version is available from Polk Audio. The RDO-194 replaces the 2000, the RDO-198 replaces the 3000.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • They are 11 Ts. Thank you, 11T Steve, for your advice. Much appreciate it. Dan
  • Nightfall
    Nightfall Posts: 10,084
    If they are 11T's you don't have SL3000 is what he was saying.
    afterburnt wrote: »
    Village Idiot of Club Polk
    pitdogg2 Posts: 27,080
    edited September 2015
    If you have SL3000 tweeters then you have the rta11tl. Call Polk cs and buy some rdo-198's as that is what is correct. You will need to pull the crossover to be sure. On the xo board will be a number please give that to us to help you better. Those sl3000 might not be correct if someone already replaced once
  • boston1450
    boston1450 Posts: 7,758
    If you have the sl-3000's your good. 198's are better. My RTA15t's say that on the box also. But they are the RTA15tl's. ejh5uodixb43.jpeg
    I replaced the sl-3000's with rd0198's....
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • skrol
    skrol Posts: 3,453
    Excellent point on . Some of the late labeled RTA-11T's were also actually RTA-11TL's with the SL-3000 tri-laminate tweeters. It is best to check what is actually in the speakers. The SL-3000 usually has a gold-ish look to the dome but cal also appear silver. It should have a foam ring around the edge of the dome. The SL-2000 used in the earlier RTA-11T and is often referred to as the fish-eye because it looks like one.
    You can also tell the RTA-11TL from the RTA-11T by cabinet features. The earlier RTA-11T had chamfered edges and a pedestal base. The RTA-11TL had squared edges and no pedestal. It also added a little plastic spoiler above the tweeter.awos0hwz9xld.jpg
    Stan
    Main 2ch:
    HT:
    Other stuff:
