Polk Audio DSW MicroPRO 1000 Power Cord?
Jstas
Picked up a Polk Audio DSW MicroPRO 1000 but it's missing the power cord. Doesn't seem like a standard cord.
Anyone know where I could get a replacement?
Expert Moron Extraordinaire
Polk CS should have them at 1-800-377-7655 if you have trouble finding one.
Does it only have 2 prongs? If yes you can use a std 3 prong cord...The oe one is pretty cheap.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Yeah, it's the two pronged one.
I only have 3 pronged cables.Expert Moron Extraordinaire
U can use the 3 prong fine I think. The grounding pin just isn't connected.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Yeah, might have the shutoff problem though but for the price I paid, I'll figure it out.Expert Moron Extraordinaire
Found a cable that'll work.
Wouldn't turn on, though.
Picked out the fuse. Blown.
Can't find a new fuse easily. Ordered a dozen from the same place I got the cable.
Should be here by the end of the week.
Stay tuned, kids! We'll blow this thing up yet!Expert Moron Extraordinaire
So it works when I replace the fuse for a little bit and then it pops the fuse.
Any idea what would cause that?Expert Moron Extraordinaire
That usually indicates a problem with the amplifier, best to contact Polk for service or replacement options.
I did, Ken. Was told to buy a $900 amplifier.
But I did discover that this is not a MicroPRO 1000, it's a 4000.
Also, I think I found the problem:
http://forum.polkaudio.com/discussion/169583/dsw-micropro-4000?new=1
Any ideas on what that green guy is?Expert Moron Extraordinaire
