Need a Speaker upgrade
Receiver: Denon AVR-3200 (yes, it's old - 80W/ch)
Turntable: Kenwood KD-3055
I currently run Boston Micro 90X satellites and I'd like to get some nice floorstanding stereo speakers. I love listening to music, especially my vinyl, but have a budget.
I was looking at the TSx440T but am unsure if my receiver would drive them properly, It has bi-wire.
Answers
  • rooftop59
    rooftop59 Posts: 8,121
    Hi Will,
    Welcome to the forum. The bi-wire feature is honestly more marketing than anything. Don't worry about it. Your receiver will drive those speakers just fine.
    I will say that is a lot of coin for those speakers when you consider other options especially used, or the possibility of nice bookshelf speakers with a subwoofer. Many here would recommend the Pioneer SP-BS22-LR. I also really like the energy RC-10. Couple either of those with this guy: http://www.hsuresearch.com/products/stf-2.html and I think you would have a two channel setup that would offer significant improvements over the polks.
    Good luck!
    Game Room 5.1.4:
    Bedroom 2.1
  • I'd like something floorstanding, no separate sub.
    tonyb Posts: 33,067
    The 440t's will work, though you haven't said exactly what the budget is so suggestions are going to be all over the map.
  • "I was looking at the TSx440T" MSRP=$349.95/ea
  • rooftop59
    will_hough wrote: »
    Why exactly? Have u heard a well setup sub bookshelf combo? Because I guarantee either of my suggestions will smoke those speakers in every way. My buddy has the m70s running of a similar receiver power wise, and I've owned the energy rc 10s with a musical 10 inch sub and if smoked the 70s in every way.
    Game Room 5.1.4:
    Bedroom 2.1
  • nguyendot
    nguyendot Posts: 3,594
    At 80w/channel a sub bookshelf will sound much better than trying to get full range out of your modest receiver.
    Main Surround -
    F1nut Posts: 51,686
    nguyendot wrote: »
    In this case, I have to agree. It takes a beefy power supply to get great bass and a 80wpc AVR doesn't have one.
    tonyb Posts: 33,067
    will_hough wrote: »
    Is that the top range of your budget ?
    If that's what you like, go for it. What the guys are trying to tell you though is that receiver won't be able to make bigger floorstanders perform at their best. Sure, you'll get sound, maybe even good sound at lower levels, but as the volume rises it will become apparent the sound quality will not be as good.
    That said, how big is this room they are going into ? I imagine somewhat small considering what you have in there now. Is this just for music or are you looking to play movies on this system too ?
    Sorry for all the questions, but we need to know some things to better help you and narrow it down some.
