What minimum standards, gave the Polk SDA range of speakers the right to be also called SRS ?
Does anybody know?
  • PolkieMan
    PolkieMan Posts: 2,446
    They are larger than, the step up from, SDA 1"s
  • I should have asked What minimum standard would give the polks the Reference badge...as CRS are smaller than SDA1's
  • Nightfall
    Nightfall Posts: 10,083
    My guess, it's just a name. Marketing.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 51,945
    The CompactReferenceSeries are not the same as the SignatureReferenceSeries. The CRS do not carry Matt Polk's signature. So, the minimum standard? Matt felt the SRS models were the pinnacle of the SDA line and worthy of his signature.
    ptrooper wrote: »
    There is no minimum standard, 2 different speakers that required different names is all. Much like todays model line up, different cabinets, drivers, crossovers, design, purpose. Think of the CRS as a bookie form with some SDA technology inside.
  • PolkieMan
    Yes SRS as aforementioned the best of the SDA series.
    Only the models larger than the SDA1's were SRS.
    CRS is the smallest of the SDA series
  • Rex81
    Rex81 Posts: 193
    Yep, I think Matt Polk's signature is the most important aspect here.
