Looking to upgrade away from polk
Well, looking to upgrade my lsi 15's after 4 years in my 2 channel set up. Believe it or not, I've only had polk speakers, with acception that I had some AR15's when I was maybe 15. I do love my polks though, the ones in the home theater will be staying. Living in Canada there isn't much to demo around here, but I trust most people's opinions on here. I actually plan on keeping my 15's. Maybe sticking them in the closet for now. I am drawn to focal 826 w's being sold locally. Budget is around 2500$ looking forward to suggestions, bookies with nice stands aren't out of the question as I have a svs sb1000. Thanks everyone.
2 channel:
Theater:
«13
  • What about Paradigm? IIRC they are a Canadian company so you might have more luck with local dealers....
  • mikeyb128
    mikeyb128 Posts: 2,885
    There is a Paradigm and mission dealer here. But for the price bracket I'm in, it may not be an upgrade, reference paradigms going for 3-4000$ But stopping by that dealer on the weekend to have a listen.
    2 channel:
    Theater:
  • mikeyb128 wrote: »
    The Signature C5 center is a beast of a center though..... I dream of using a full setup of their speakers.....
  • mikeyb128
    DSkip wrote: »
    If you weren't Canadian, you should be all over those Mini X I have posted. I don't know what $2500 Can gets you anymore?
    Our dollar is quite bad. Otherwise I would be all over those. And I already did the math. About 3300 Canadian, not even shipping factored in. Ouch..
    2 channel:
    Theater:
  • Emlyn
    Emlyn Posts: 4,710
    What qualities are you looking for that would be different than in other speakers you have had? Brighter? More accurate bass?
    Focal speakers would provide those qualities.
  • mikeyb128
    Not brighter, maybe a little more full. I do like the laid back tweeter in the lsi. Something that images really well. Bass is not a huge issue as I have a sub. I've noticed the midrange kind of over whelms the tweeters with the lsi. I like these speakers, I just want something different. I will have to do some digging to get some demos going, so I can get a better idea.
    2 channel:
    Theater:
  • mikeyb128
    DSkip wrote: »
    How about the Sonus Faber Venere series? Great sound and quite different from the house sound they are known for. I got to spend more time with the 3.0's last weekend and still enjoy them. There is a pair of 2.5's listed on Canuck AM for $2500. I'm not sure how good a price that is on the used market, especially up that way.
    All I see are sda srs? Not too familiar with the older series. But he wants 3200$ and they are 120 pounds each across the country. wont fit my space at Alll. I will check out Sonus fabers.
    2 channel:
    Theater:
  • What about upgrading the crossovers in your LSi's? I've read that that can make a huge improvement.
  • mikeyb128
    I have DB upgraded woofers and vr3 fortress crossovers. It made a huge improvement. Just find myself wanting something different.
    2 channel:
    Theater:
  • Emlyn
    Emlyn Posts: 4,710
    PSB and Bryston's new lines of speakers may be worth looking into. Both Canadian brands and they have more than one line of speakers now for different budgets. Monitor Audio speakers have always impressed me for what they are.
  • mikeyb128
    Emlyn wrote: »
    Going to demo some silver 8 and 10 this weekend. Looking forward to it. The guy that is selling the focals locally won't respond, which I'm kinda of disappointed. Ah well.
    2 channel:
    Theater:
  • Joey_V
    Joey_V Posts: 8,600
    edited September 2015
    I would look into BW. Check out their recently discontinued PM1 or perhaps the current CM6.
    Used Cremona Auditor M would be fantastic.
  • cvc
    cvc Posts: 65
    Monitor Audio always get great reviews.. Always!
  • mikeyb128
    I really like the Sonus faber venere 2.5. But seriously? 43 pound speaker that's 43 inches tall? Seems like a light weight. Too bad I can't get my ears on them. This may be harder than I thought!
    2 channel:
    Theater:
  • mikeyb128
    Joey_V wrote: »
    Those look sweet!
    2 channel:
    Theater:
    tonyb Posts: 33,072
    It's hard to recommend another speaker for ya without knowing what will be hooked up to them, size of the room, preferences in sound.
    The Cremona is an excellent speaker in it's own right but requires some careful gear matching and positioning....as most SF speakers do.
    There's more variants in speaker sound than you can shake a stick at so find whats available to you up in the frozen tundra. If you want to depart from the classic Polk sound, some of my favs have been Legacy/PBN Montana/Tyler/ Salk and countless others. Stay away from British speakers as they carry a more laid back sound in general, much like the LSI's your trying to depart from. Good luck to you and let us know what you find.
    tonyb Posts: 33,072
    I meant if he can find those brands used up there Skip. Many would be in his budget easily used. US Audio Mart has a Canadian version too worth a look see.
  • If you don't mind going vintage/used and (probably cheap too, for what you get) try Dahlquist DQ-10 and DQ-20, Meadowlark, A/D/S, and Magneplanar (New or used).
    Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
  • mikeyb128
    Ok as tonyB requested. My gear:
    B&K reference s2 mono blocks
    Benchmark dac 1 pre
    Heimdall xlrs
    Signal cable magic power cables for amp
    Heimdall speaker cables with Norse biwire jumpers
    Svs sb1000
    Teac tn300
    2 channel:
    Theater:
  • Joey_V
    Joey_V Posts: 8,600
    I like BW's current offerings. Maybe you can find a used 805 Diamond?
  • mikeyb128
    Joey_V wrote: »
    Found some in Ontario. No boxes and won't ship. But he wants 4000$. Found a tannoy/focal dealer, going to check them out on the weekend, none of these shops are open when I get off work!
    2 channel:
    Theater:
  • erniejade
    erniejade Posts: 6,321
    PSB is also a choice. The Imagine T2 I thought was a good sounding speaker.
  • Nightfall
    Nightfall Posts: 10,084
    afterburnt wrote: »
    Village Idiot of Club Polk
  • I'm currently in mad love with a new pair of Martin Logan Motion 15s. For some tiny bookies, their sound is beyond anything I could have hoped for. The folded ribbon tweeter in particular is a little piece of alchemical magic. These are the smallest of the Motion line, and at 800/pr US they're not budget busters. I haven't been lucky enough to audition any of the other larger speakers in the series, but if you have the opportunity, I would suggest adding them to your list of possibles. Best of luck finding the sound you seek!
    AVR: Denon X3200W
    Mains: Polk TSx440T
    Center: Polk CS10
    Surround: Polk TSi300
    Sub: Polk PSW110
    Video: LG OLED65B6P Panel
    BDP: Sony BDP-S6500 Blu-ray player
  • Joey_V
    Joey_V Posts: 8,600
    mikeyb128 wrote: »
    Joey_V wrote: »
    Yes! Listen to the 1008BE.
    tonyb Posts: 33,072
    Ya know, almost forgot about Revel, put them on the list, excellent suggestion also. A used pair of Salk HT3's too.
    Not so sure about the Nordost cables though on your gear list coupled with the Benchmark and amps. It's a synergy thing your trying to find.
    My best advice is to start with a speaker that has characteristics to your liking and then try swapping stuff in and out until you reach your desired bliss. Read Mr. Buhl's long winded post on his synergy search. lol
  • mikeyb128
    tonyb wrote: »
    I've found it with my Lsim 705 MIT shot guns1/magnum set up. And it's fantastic! This weekend focal, paradigm, tannoy and monitor audio for demos.
    2 channel:
    Theater:
  • mikeyb128
    I've got a serious eye on these...
    2 channel:
    Theater:
    tonyb Posts: 33,072
    I know you like those because they are made up there, but in my opinion it's not a big deviation from the Polk sound your looking to move away from. Just sayin'...
    They will however have a more forward presentation than the LSI's.
  • mikeyb128
    tonyb wrote: »
    I do! And thanks for your honesty. I haven't even heard them yet. They look good on paper though. But I have a full day of demos tomorrow. I'm looking forward to demoing some focals. And even monitor audio. Why am I impressed monitor audio even has the wire used in the cabinets in their specs?
    Staring to realize these 15's are going to be hard to beat with this budget. Might have to stretch it a little.
    2 channel:
    Theater:
